Forum: FPGA, VHDL & Verilog SATA controller program execution
Author: Sunayana C. (sunayana_c)
Hello,
I have the SATA HOST controller program from the university of
massachusettes for ML405 board. However if I try to run the downloaded
project on my Xilinx ISE 14.6, it gives many errors. I am just trying to
simulate the project without connecting to the hardware. What might be
the reason for so many errors and how should it be solved?
The snapshot of the error list is attached with this file.
I actually downloaded the project file created by one Mr: Gormann from
this website.
http://www.ecs.umass.edu/ece/tessier/rcg/virtex4-s...
I have not yet connected any hardware and just wanted to run this
project on my Xilinx ISE 14.6. When I did so I got many errors. I want
yo know if its required to connect the hardware before executing this
project? Also do I need some user interface softwares like tera com,
impact to be downloaded onto my PC as I want to implement SATA read /
write. Is it possible that the entire project has not been uploaded by
the designer on the website I have listed? Please suggest about how this
problem should be solved.
I have been asked to adapt any previously written code for a SATA
controller for the ML 605 board which we have and demonstrate the read /
write capability and we donot have any purchased IP core. Please advice
on how to go about doing this?
> this website.
Did you adapt the project file to your drive an paths? Or did you
generate a new project file? Did you do a cleanup project files?
Just to be on the safe side: no spaces in path names...
Author: Duke Scarring (Guest)
I see only warnings and no errors in your screenshot.
And I found almost no design without warnings...
Duke
Author: sunayana chakradhara (Guest)
yes but i need to implement this design on a virtex 6 board and without
using an IP core. How should this be done?
  • [vhdl]VHDL code[/vhdl]
