Forum: FPGA, VHDL & Verilog Syntax Help with Project
Author: Annon (Guest)
--Baseball Scorekeeper
--STRIKES
library IEEE;
use ieee.std_logic_1164.all;
entity strikes is
port     (button_press        : in std_logic;
       reset                  : in  std_logic;
       led_out            : out std_logic_vector (1 downto 0)
end entity;
architecture strikes_arch of strikes is
signal tempLED : std_logic_vector (1 downto 0);
begin
  process ( button_press)
    begin
    if reset='1' then tempLED <="00";
        elsif rising_edge(button_press) then
      case tempLED is
      when "00" => tempLED <="01";
      when "01" => tempLED <="11";
      when "10" => tempLED <="00";
      when "11" => tempLED <="00";
      when others => tempLED <= "00";
        end case;
    end if;
  end process;
led_out <= tempLED;
end strikes_arch;
--BALLS
library IEEE;
entity balls is
       led_out            : out std_logic_vector (2 downto 0)
end entity;
architecture balls_arch of balls is
signal tempLED : std_logic_vector (2 downto 0);
begin
    begin
    if reset='1' then tempLED <="000";
      case tempLED is
      when "000" => tempLED <="001";
      when "001" => tempLED <="011";
      when "010" => tempLED <="000";
      when "011" => tempLED <="111";
      when others => tempLED <= "000";
        end case;
    end if;
  end process;
led_out <= tempLED;
end balls_arch;
library IEEE;
entity Baseball is
port   ( b1, b2, b3    : in std_logic;
      --mst_rst   : in std_logic;
      strikes   : out std_logic_vector (1 downto 0);
      balls    : out std_logic_vector (2 downto 0)
end entity;
architecture Baseball_arch of Baseball is
--signal tempStrikes :  std_logic_vector (1 downto 0);
--signal tempBalls   :  std_logic_vector (2 downto 0);
--signal temprst     : std_logic;
component strikes is
end component;
component balls is
end component;
begin
  UX0: port map strikes (button_press=> b1, reset=>b3, led_out=>strikes);
  UX1: port map balls   (button_press=> b2, reset=>b3, led_out=>balls );
end Baseball_arch;
Error:
Error (10500): VHDL syntax error at Baseball.vhd(121) near text "port";
expecting "(", or an identifier ("port" is a reserved keyword), or a
sequential statement
Error (10500): VHDL syntax error at Baseball.vhd(122) near text "port";
**The "port" it's referring to is in my port mapping section**
I'm not sure if it has something to do with the internal signals.
Although, looking at my design on paper the only thing connecting the
"strikes" and "balls" blocks together is my reset which is just tied to
an external button (b3). Hmm..it's always something small. I'd
appreciate a look.
Thanks.
This will give a wrong simuslation due to a wrong sensitivity list:
 process ( button_press) begin
    if reset='1' then
       tempLED <="00";
And additionally: a button is never(!!!) a clock source. But you will
see that in real life later on...
But your actual problem is as reported here:
And there:
Check the order of "port map" and "strikes", as well as "port map" and
"balls"...
: Edited by Moderator
Author: Jay JA (jboss10)
Thank you Lothar. You are always willing to help. I figured out what was
wrong and was able to compile. I do understand, in a real-world
application this should/would never be done, but for the sake of my
project it suffices.
Question..I'm trying to figure out how to make this work so when the
baseball count is, let's say, 3-balls and 1-strike. If the next ball is
thrown is a "ball" then both the strikes and balls LEDs get reset back
to "00" and "000", respectively.
Do I create another process? Or another entity entirely? I've done it
almost 10 different ways and none of which have worked or compiled. It's
tricky trying to get both balls and strikes to get reset when they are
in totally different processes. I've only been coding in VHDL for maybe
two months so bare with me.
I appreciate your help. Enjoy the holidays.
**Corrected Code:
--STRIKES
library IEEE;
entity strike is
end entity;
architecture strike_arch of strike is
begin
    begin
      case tempLED is
        end case;
    end if;
  end process;
led_out <= tempLED;
end strike_arch;
--BALLS
library IEEE;
entity ball is
end entity;
architecture ball_arch of ball is
begin
    begin
      case tempLED is
        end case;
    end if;
  end process;
led_out <= tempLED;
end ball_arch;
library IEEE;
entity Baseball is
port   ( b1_strikes, b2_balls, b3_hit    : in std_logic;
end entity;
component strike is
end component;
component ball is
end component;
begin
  UX0: strike port map  (button_press=> b1_strikes, reset=>b3_hit, led_out=>strikes);
  UX1: ball port map    (button_press=> b2_balls, reset=>b3_hit, led_out=>balls);
end Baseball_arch;
  • [vhdl]VHDL code[/vhdl]
