Forum: FPGA, VHDL & Verilog FIR Filter Sampling Frequency
von Roger S. (roger237)
I am multiplying a 2kHz sinewave with another 100khz sinewave to obtain
a dsb-sc signal. These sinewaves were designed using DDS cores.
I am also using a 50mHz clock.  I would like to demodulate this dsb-sc
signal.  I am doing this by multiplying the dsb-sc signal with the
carrier (100khz signal).  Now i have to pass this signal through a low
pass filter.
I have generated a coefficient file (.coe) from matlab and am using the
FIR compiler to actually generate the low pass filter.
I have put 50mhz as the input clock frequency but the problem is that i
am not exactly sure what to put in as the sampling frequency.  Could
anyone provide some help regarding this.
Thanks a million
anyone please?
von Matthias (Guest)
The temporal distance between your samples is the sample time. So if you
calculate every 1/50M seconds a new output, then 50MHz is your sample
frequency.
BR
So you are telling me that for both the sampling frequency and clock
frequency i should enter 50 mhz?
von Achim S. (Guest)
If you provide a new sample every CLK-Cycle, then the answer is: Yes
If you provide a new sample only every nth CLK-Cycle, then the answer
is: No.
You may e.g. have a sampling rate of 500kHz and a CLK of 50MHz. Then you
enter the corresponding numbers and tell the FIR every 100th CLK cycle,
that there is a new sample at its input. If think the corresponding pin
is named ND (New Data).
If your data comes from an external ADC, the sample rate will often be
lower than 50MHz. If all your data generation and data handling is done
internally in the FPGA, then you could of course provide a new sample
every 20ns. But you're the only one who knows. We may only guess...
