Forum: FPGA, VHDL & Verilog UART communication through Nexys 3
von Roger S. (roger237)
I am currently working on a project which involes manipulation of input
data, (which can be anything, probably audio or text)  I am using a
Nexys 3 board which has an on-board USB UART for data communication.
This UART allows PC applications to communicate with the board using
standard Windows COM port commands.
As stated on the reference manual of the Nexys 3 board, Serial port data
is exchanged with the FPGA using a two-wire serial port (TXD/RXD) and
software flow control (XON/XOFF). After the drivers are installed, I/O
commands from the PC directed to the COM port will produce serial data
traffic on the
N17 and N18 FPGA pins.
First of all, do you have any idea of any software I can use to
literally be sending a file to my board... Also would someone care to
explain how I would have access to this data as I'm pretty new to these
things.
I have searched for some tutorials on this but couldnt find any.
Looking forward to your replies! :)
Serach for "terminal software" and you will find things like Hyperterm
(part of Windows) or RealTerm, TeraTerm or HTerm...
> Also would someone care to explain how I would have access to this data
> as I'm pretty new to these things.
You will need some kind of HDL description (Verilog or VHDL) to decode
the bitstream and do something with it.
Your searched the wrong way/words. There are plenty of RS232
implementations on the internet...
: Edited by Moderator
Does that mean that through the use of terminal software I would avoid
the need of having to write a program of my own in order to be able to
communicate with my board?
What would be the commands that I need to pass should i for example need
to send an audio which is 1.3mb through com1 ?
Yes.
No one sends encoded audio through a RS232 connection...
What should be the purpose this?
What the heck do you want to do at all?
I would need to perform amplitude modulation on this data. (note data
can be either audio or text)
You're saying that it cannot be done ?
von jonas biensack (Guest)
It can be done, but it makes no sense. You need to decode the audio in
your own special format, transfer over RS232 (even for 2 channel audio
16 bit @4400kHz it is to slow). Then you need to buffer on the fpga
board (no realtime calc. because of slow rs232) which needs big ram
resources on the fpga...
kind regards Jonas
Of course it can. But it is senseless! Or let me say: I cannot see any
sense. Maybe I don't see the purpose of the whole thing. Whats the
output after processing the data?
> (note data can be either audio or text)
You are speaking in riddles! AM on text?
Is it something like that:  xxxxXXXXxxxxXXXX?
Audio is NOT mp3!
mp3 is a encoded data which contains audio information. But you cannot
simply play it on a speaker.
von asdfg (Guest)
Here is a good tutorial on RS232 communication using VHDL.
https://www.youtube.com/watch?v=fMmcSpgOtJ4
