Forum: FPGA, VHDL & Verilog Interface AD7655 with FPGA using VHDL
von jeorges FrenchRivera (Guest)
Hi guys,
I'm writing A VHDL code to interface a 16-bit serial ADC to an FPGA and
I have some questions about my methodology. The ADC that I'm using is
the AD7655 from analog device.
I think the code should be very simple, but I just want to get a second
opinion so I don't end up in the wrong direction.
In fact, I'm not sure if I'm asserting and reading the data correctly.
Anyway, this is methodology:
1. Since the ADC is going to be operating in External Clock Data Read
(Previous) During Convert mode(page 22 of
http://www.analog.com/static/imported-files/data_sheets/AD7655.pdf, my
input clock needs to be 32 MHz at least. This is going to be fed into
the ADC at all time. For this reason. I followed the detailed timing in
Figure 33 in the datasheet to write my VHDL code.
2. Make a simple state machine with five state cases,ADC_STATE IS
(IDLE,START,CONV_A,CONV_B,CATCH);
3. CONV will be asserted 1 in IDLE State, the CONV is asserted 0 in
START state.
4. At the rising edge when the state is START, I make a test of BUSY
signal, if it's high the  CONV_A state can start, in which the channel A
is converted and date grabbed and placed into the register. I will stop
at CLK = 16, and at CLK = 16, the  CONV_B state can be started.
5. in CONV_B state, the channel B is converted and date grabbed and
placed into the register. I will stop at CLK = 16, and at CLK = 16, the
CATCH state can be started.
6. In the CATCH state, I will put conversion values of channel A and
channel B into another registers. Everything will now repeat by putting
the state to IDLE one.
I am in the right direction? it my first experience to write code from a
timing diagram.
In case you're interested, my code can be attached.
I'd appreciate any input you have for modification to get this thing
going.
Best regards
von jeorges F. (Company: xlue) (khal1985)
Please i need your remarks,
Best regards
von Duke Scarring (Guest)
What is your problem?
Do you have a testbench?
If I had your task, I would write a model for the AD7655, add a
testbench and check the behaviour of my FSM against the model.
Duke
My problem is to to write a testbench basing on the ADC specification.
Best regards
