Forum: FPGA, VHDL & Verilog Port Map Errors
Author: Jay JA (jboss10)
I have quite a large project involving a Traffic Light system. I'm at
the point of port mapping all of my blocks together within the top
entity as I will post..
library IEEE;
use ieee.std_LOGIC_1164.all;
entity Final_TLSystem is
port
   (V_Sensor          :  in  std_logic;
    mclk         :  in  std_logic;
    mst_reset       :  in  std_logic;
    Traffic_Lights   :  out std_logic_vector ( 5 downto 0)
end Final_TLSystem;
  architecture Final_TLSystem_arch of Final_TLSystem is
  signal internal     : std_logic_vector (1 downto 0);
  signal tempTrig : std_logic_vector (1 downto 0);
  signal tempclk   : std_logic;
  signal tempTime : std_logic_vector (1 downto 0);
  component SeqLogic is
  port     (clk_in  : in  std_logic;
         TS      : in  STD_logic;
         TL      : in  std_logic;
         V       : in  std_logic;
         S        : out std_logic_vector (1 downto 0)
  end component;
component TLightSystem is
  port  (State_In : in  std_logic_vector  (1 downto 0);
        Lights   : out std_logic_vector (5 downto 0);
       TS_TL   : out std_logic_vector (1 downto 0)
end component;
--component FreqDivider is
  --  port(
    --     clk_24MHz : in STD_LOGIC;
     --    clk_24KHz : out STD_LOGIC
--end component;
component pulse_counter is
port     ( clk_24Khz     : in  std_logic;
        trigger_long  : in  std_logic;
        trigger_short : in  std_logic;
        TS         : out std_logic;
        TL         : out std_logic
end component;
begin
  U1 : SeqLogic      port map (V=> V_sensor, internal(0)=>S(0), internal(1)=>S(1),tempTrig(0) => TS, tempTrig(1)=>TL, tempclk=>clk_in, reset=> mst_reset);
  U2 : TLightSystem  port map (Lights=>Traffic_Lights, tempTrig(0)=> TS_TL(0), tempTrig1=> TS_TL(1), tempS0=> State_In(0), tempS1 => State_In(1));
  U3 : pulse_counter port map (tempclk=>clk_24KHz, tempTime(0)=> TS, tempTime(1)=>TL, tempTrig(0)=> trigger_long, tempTrig(1)=>trigger_short, clk_24KHz=>mclk);
end Final_TLSystem_arch;
Errors I'm receiving:
"type of formal parameter "internal" does not match type or value"
"object "S" is used but not declared"
"cannot associate formal port "internal" of mode "object" with an
expression"
..same errors trickle down with tempTrig, clk_in, TS, TL, tempClk, and
reset. I'm clearly not connected this right.
Thanks for any input. Let me know if any other information is needed.
Ouch! There are multiple basic bugs in this description.
First:
A port map is "port_signal => external_signal" from the view of the
component.
Your tempclk is the external signal:
and your clk_24khz is the port signal:
So this assignment here (and as far as I see most of the others also) is
the wrong direction:
> U3 : pulse_counter port map (tempclk=>clk_24KHz, ...
Second:
You MUST(!!) pass eyery asynchronous external signal through at least
one better are two synchronisation flipflops before you use it inside
your design. See this here:
http://www.lothar-miller.de/s9y/archives/64-State-...
Third:
> mclk, tempclk, clk_24khz ...
Far way much too much clocks in this beginners design!!
A beginners design must have exactly 1 clock. All the rest is done by
clock enables. See there the very last code snippet:
http://www.lothar-miller.de/s9y/archives/80-Hello-...
The whole design has only clk as clock. 't' is the clock enable.
Author: asd (Guest)
wrong order of port map assignments. Should be S(0)=>internal(0) for
example...
Would also be much more readable with some line feeds:
U1 : SeqLogic
  port map (
   V      => V_sensor,
   S      => internal,
   TS     => tempTrig(0),
   TL     => tempTrig(1),
   clk_in => tempclk,
   reset  => mst_reset);
something in that style...
  • [vhdl]VHDL code[/vhdl]
