Forum: FPGA, VHDL & Verilog VGA pins compatibility for Spartan 3 and Altera DE2 (verilog)
Author: Charan Mehta (Guest)
There's a Verilog description written for Spartan 3, which is supposed
to display something on a VGA. It has a 3-bit output "rgb" for the VGA
(declared as output [2:0] rgb). In the pin assignments, there are 3 pins
designated for the 3-bit rgb output.
If we want to write the Verilog description with the same functionality
(displaying on the VGA) for an Altera DE2, do we have to change this VGA
output for it to work properly? I'm confused because the standard pin
assignments for the DE2 include 30 bits output for VGA. That is, there
are 10 pins assigned each for VGA_R, VGA_G, and VGA_B.
So, how are we supposed to display the output on VGA of the Verilog
description for Spartan 3 on an Altera DE2? What's the matter regarding
the VGA pin assignments (3-bit vs. 30-bit) and how do we go about this
compatibility issue?
Author: Duke Scarring (Guest)
It's the numer of selectable colors: 3 bit = 8 colors, 30 bit = 2^30
colors.
You just need a mapping. The way from 8 to 2^30 is easy. Just copy the
bit for the color (eg. red) in the vector of ten bits.
Duke
Author: Embe Sys (Company: Sparrow SoftTech) (embesys)
Helllo
Here I want to display "A" on my display using xc6lx9 tqg144 spartan 6 package..If I pass continuous '0' or '1' then its working very well But I f I am passing any particular pattern then it does not ...It will mix up data and randering in pixel....
Code is given below :
-- FileName: vga_controller.vhd
-- Dependencies: none
-- Design Software: Quartus II 64-bit Version 12.1 Build 177 SJ Full Version
-- HDL CODE IS PROVIDED "AS IS." DIGI-KEY EXPRESSLY DISCLAIMS ANY
-- WARRANTY OF ANY KIND, WHETHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
-- LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
-- PARTICULAR PURPOSE, OR NON-INFRINGEMENT. IN NO EVENT SHALL DIGI-KEY
-- BE LIABLE FOR ANY INCIDENTAL, SPECIAL, INDIRECT OR CONSEQUENTIAL
-- DAMAGES, LOST PROFITS OR LOST DATA, HARM TO YOUR EQUIPMENT, COST OF
-- PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY OR SERVICES, ANY CLAIMS
-- BY THIRD PARTIES (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF),
-- ANY CLAIMS FOR INDEMNITY OR CONTRIBUTION, OR OTHER SIMILAR COSTS.
-- Version History
-- Version 1.0 05/10/2013 Scott Larson
-- Initial Public Release
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
--USE ieee.std_logic_arith.all;
ENTITY vga_controller IS
GENERIC(
OFFSET : INTEGER := 1;
HEIGHT : INTEGER := 16;
WIDTH : INTEGER := 8;
START_X : INTEGER := 100;
START_Y : INTEGER := 80;
h_pulse : INTEGER := 120; --horiztonal sync pulse width in pixels
h_bp : INTEGER := 64; --horiztonal back porch width in pixels
h_pixels : INTEGER := 800; --horiztonal display width in pixels
h_fp : INTEGER := 56; --horiztonal front porch width in pixels
h_pol : STD_LOGIC := '1'; --horizontal sync pulse polarity (1 = positive, 0 = negative)
v_pulse : INTEGER := 6; --vertical sync pulse width in rows
v_bp : INTEGER := 23; --vertical back porch width in rows
v_pixels : INTEGER := 600; --vertical display width in rows
v_fp : INTEGER := 37; --vertical front porch width in rows
v_pol : STD_LOGIC := '1'); --vertical sync pulse polarity (1 = positive, 0 = negative)
PORT(
--cnt : inout std_logi
payal: inout std_logic_vector(1 downto 0):="10";
Y : inout std_logic:='0';
BELL : out std_logic;
clk25: in std_logic;
addr: inout std_logic_vector(10 downto 0);
data: inout std_logic_vector(7 downto 0):="00000000";
blue : out std_logic;
green : out std_logic;
red : out std_logic;
--clk25 : IN STD_LOGIC; --pixel clock at frequency of VGA mode being used
reset_n : IN STD_LOGIC; --active low asycnchronous reset
h_sync : INOUT STD_LOGIC; --horiztonal sync pulse
v_sync : OUT STD_LOGIC; --vertical sync pulse
disp_ena : INOUT STD_LOGIC; --display enable ('1' = display time, '0' = blanking time)
column : INOUT INTEGER; --horizontal pixel coordinate
row : INOUT INTEGER; --vertical pixel coordinate
n_blank : OUT STD_LOGIC; --direct blacking output to DAC
n_sync : OUT STD_LOGIC); --sync-on-green output to DAC
END vga_controller;
ARCHITECTURE behavior OF vga_controller IS
--signal clk25 : std_logic;
-- component clocking
-- port (
-- clk50 : in std_logic;
-- clk25 : out std_logic
-- end component;
--COMPONENT text
--PORT(
-- --cnt : out std_logic;
-- clk: in std_logic;
-- addr: inout std_logic_vector(10 downto 0);
-- data: out std_logic_vector(7 downto 0);
-- Y : inout std_logic
--END COMPONENT;
CONSTANT h_period : INTEGER := h_pulse + h_bp + h_pixels + h_fp; --total number of pixel clocks in a row
CONSTANT v_period : INTEGER := v_pulse + v_bp + v_pixels + v_fp; --total number of rows in column
type rom_type is array (0 to 15)
of std_logic_vector(7 downto 0);
-- ROM definition
constant ROM: rom_type:=(
"00000000", -- 0
"00000000", -- 1
"00010000", -- 2 *
"00111000", -- 3 ***
"01101100", -- 4 ** **
"11000110", -- 5 ** **
"11000110", -- 6 ** **
"11111110", -- 7 *******
"11000110", -- 8 ** **
"11000110", -- 9 ** **
"11000110", -- a ** **
"11000110", -- b ** **
"00000000", -- c
"00000000", -- d
"00000000", -- e
"00000000" -- f
BEGIN
-- CLKMGNT : clocking
-- port map (
-- clk50 => clk50,
-- clk25 => clk25
--generator : text
--port map(
--Y => Y,
--clk => pixel_clk,
--data => data,
--addr => addr
BELL <= '1';
n_blank <= '1'; --no direct blanking
n_sync <= '0'; --no sync on green
-- pppp <= "11111111";
P1:PROCESS(clk25)
VARIABLE h_count : INTEGER RANGE 0 TO h_period - 1 := 0; --horizontal counter (counts the columns)
VARIABLE v_count : INTEGER RANGE 0 TO v_period - 1 := 0; --vertical counter (counts the rows)
BEGIN
-- IF(reset_n = '0') THEN --reset asserted
-- h_count := 0; --reset horizontal counter
-- v_count := 0; --reset vertical counter
-- h_sync <= NOT h_pol; --deassert horizontal sync
-- v_sync <= NOT v_pol; --deassert vertical sync
-- disp_ena <= '0'; --disable display
-- column <= 0; --reset column pixel coordinate
-- row <= 0; --reset row pixel coordinate
IF(clk25'EVENT AND clk25 = '1') THEN
--counters
IF(h_count < h_period - 1) THEN --horizontal counter (pixels)
h_count := h_count + 1;
ELSE
h_count := 0;
IF(v_count < v_period - 1) THEN --veritcal counter (rows)
v_count := v_count + 1;
ELSE
v_count := 0;
END IF;
END IF;
--horizontal sync signal
IF(h_count < h_pixels + h_fp OR h_count > h_pixels + h_fp + h_pulse) THEN
h_sync <= NOT h_pol; --deassert horiztonal sync pulse
ELSE
h_sync <= h_pol; --assert horiztonal sync pulse
END IF;
--cnt <= h_sync;
--vertical sync signal
IF(v_count < v_pixels + v_fp OR v_count > v_pixels + v_fp + v_pulse) THEN
v_sync <= NOT v_pol; --deassert vertical sync pulse
ELSE
v_sync <= v_pol; --assert vertical sync pulse
END IF;
--set pixel coordinates
IF(h_count < h_pixels) THEN --horiztonal display time
column <= h_count; --set horiztonal pixel coordinate
END IF;
IF(v_count < v_pixels) THEN --vertical display time
row <= v_count; --set vertical pixel coordinate
END IF;
--set display enable output
IF(h_count < h_pixels AND v_count < v_pixels) THEN --display time
disp_ena <= '1'; --enable display
ELSE --blanking time
END IF;
END IF;
END PROCESS;
P2:PROCESS(disp_ena, row, column , h_sync)
VARIABLE I : INTEGER RANGE 0 TO 7 := 0;
VARIABLE CHARX : INTEGER RANGE 0 TO 7 := 0;
VARIABLE CHARY : INTEGER RANGE 0 TO 15 := 0;
BEGIN
IF(disp_ena = '1') THEN
if(column = START_X-1) then
if(row = START_Y)then
Y<= '1';
end if;
end if;
if(row > (START_Y - OFFSET)and row < START_Y + HEIGHT) then
if(column > (START_X - OFFSET )and column < START_X + WIDTH) then
if(data(CHARX) = '0' or data(CHARX) = '1') then
IF (data(CHARX) = '0') THEN
red <='1';
green <= '1';
blue <= '1';
ELSE IF(data(CHARX) = '1') THEN
red <='0';
green <= '0';
blue <= '1';
END IF;
END IF;
if(CHARX = 7) then
CHARX := 0;
if (CHARY = 15 ) then
CHARY := 0;
else
CHARY := CHARY+ 1;
Y<= '1';
end if;
else
CHARX :=CHARX + 1;
if (Y = '1') then
Y <= '0';
end if;
-- IF(I = 7)THEN
-- I := 0;
-- Y<= '1';
-- ELSE
-- I := I+1;
-- if (Y = '1') then
-- Y <= '0';
-- end if;
-- END IF;
end if;
end if;
else
-- Y <= '0';
-- end if;
red <='1';
green <= '1';
blue <= '1';
end if;
else
red <='1';
green <= '1';
blue <= '1';
-- Y <= '0';
-- end if;
CHARX := 0;
end if;
ELSE
red <='0';
green <= '0';
blue <= '0';
END IF;
END PROCESS;
P3 : PROCESS (Y)
VARIABLE CNT : INTEGER RANGE 0 TO 15 := 0;
BEGIN
IF(Y = '1') THEN
data <= ROM(CNT);
IF (CNT = 15 )THEN
CNT := 0;
ELSE
CNT := CNT+1;
END IF;
ELSE
data <= ROM(CNT);
END IF;
END PROCESS;
END behavior;
jyhjgjnhgj
  • [vhdl]VHDL code[/vhdl]
