Forum: µC & Digital Electronics Drive 12V 15A load with PWM 18V-48V 2A
von Saif B. (app)
I'm new in the field of electronics.
I'm working on a study project to control the heating power supplied by
the PTC ceramic heater.
The specifications of the ceramic heater are (12 V/DC 150 W, 15A ).
Here is the link of the heating element
http://www.conrad.de/ce/de/product/532894/Heizelement-12-VDC-150-W-L-x-B-x-H-90-x-27-x-17-mm
As far as I understand basic circuits, the steady current of 15A must be
provided to the load (Ceramic heater) all the time. But I can apply
variable voltage input. This could help me to get variable heating
power, e.g, from 0W, 45W, 75W, 150W by changing the input voltage to 0V,
3V, 5V, 10V. I can measure both the voltage across the heating element
as well as the current flowing through the circuit. The problem,
however, I'm facing is that the module I got to interface with the
heating element is either an analog output module with (-10V to 10V,
20mA) output or a PWM module (18V to 48V, max 2A). Since, the modules do
not match my loads , so I can't connect them directly.
Does any of you know how can I realize an interface to connect either my
PWM module of Analog I/O module, whichever possible, to the Ceramic
heater?
Many thanks for your suggestions.
Regards,
