Forum: FPGA, VHDL & Verilog 4-Bit Structural Adder using port map
von Jay J. (jboss10)
I have this 4-bit adder that I'm having trouble compiling.
--This snippet of code was given to us. From here, we needed to create the structural design with the correct port mapping.
entity adder is
                port       (Ain,Bin,Cin : in std_logic;
                            Sout,Cout : out std_logic);
end entity adder;
architecture adder_arch of adder is
     begin
               Sout <= Ain xor Bin xor Cin;
               Cout <= (Bin and Cin) or (Ain and Bin) or (Ain and Cin);
end architecture adder_arch;
--End of given code
--Start of my code
entity FourBit_Adder is
 port (          a  : in  std_logic_vector (3 downto 0);
    b  : in  std_logic_vector(3 downto 0);
    c_in  : in  std_logic;
    c_out  : out  std_logic;
    sum  : out  std_logic_vector(3 downto 0)
end FourBit_Adder;
architecture FourBit_Adder_arch of FourBit_Adder is
 signal S: std_logic_vector(2 downto 0);
30
31
32
 component adder is
33
     port(
34
       Ain, Bin, Cin: in std_logic;
35
       Sout, Cout : out std_logic);
36
37
end component;
38
39
40
41
begin
42
43
FULLA0: adder port map ( Ain => a(0),Bin => b(0),Cin => c_in,Cout => c_in,Sout => sum(0));
44
FULLA1: adder port map ( Ain => a(1),Bin => b(1),Cin => S(0),Cout => S(1),Sout => sum(1));
45
FULLA2: adder port map ( Ain => a(2),Bin => b(2),Cin => S(1),Cout => S(2),Sout => sum(2));
46
FULLA3: adder port map ( Ain => a(3),Bin => b(3),Cin => S(2),Cout => c_out,Sout => sum(3));
47
48
end architecture FourBit_Adder_arch;
When compiling, I'm getting the error message "std_logic_vector" is used
but not declared. Not sure what's up. I appreciate your feedback.
I'm using Altera's Quartus II software version 13.1
In both cases something is missing before the keyword "entity". Just
have a look how every VHDL description starts...
> --End of given code
Also after this line something is missing. Every VHDL module has the
same structure:
- libraries/packages
- entity
- architecture
All those keywords must occur in a "usual" VHDL module. Just have a
look for simple samples about components or type the keywords "vhdl
structural adder" into google. You will find lots of hits...
My mistake, I just forgot to post with the libraries included. I don't
need the library statement twice in one VHDL code, correct? You said in
both cases something is missing before entity unless you just were
referring to it once.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity adder is
end entity adder;
     begin
 port (  a    : in  std_logic_vector(3 downto 0);
end FourBit_Adder;
30
31
32
33
34
 component adder is
35
     port(
36
37
38
39
end component;
40
41
42
43
begin
44
45
46
47
48
49
50
@Lothar Miller
I figured it out! Thank you for your help! I did forget to place the
library in the correct spot and my port mapping was incorrect.
--Revised edition
library ieee;
entity adder is
end entity adder;
     begin
library ieee;
 port (  c_in    : in  std_logic;
      b  : in  std_logic_vector (3 downto 0);
30
end FourBit_Adder;
31
32
33
34
35
 component adder is
36
     port(
37
38
39
40
end component;
41
42
43
44
begin
45
46
        FULLA0: adder port map ( Ain => a(0),Bin => b(0),Cin => c_in,Cout => S(0),Sout => sum(0));
47
48
49
50
51
Welcome!
