Forum: FPGA, VHDL & Verilog Error when using with-select-when in VHDL
Author: Ayush Khemka (ayushkhemka)
Can someone explain to me this error and how to solve it?
architecture xxx of yyy is
signal wrptr,rdptr: std_logic_vector(n-1 downto 0);
begin
process(reset,clk)
begin
end process;
with rdptr select
with wrptr select
process(we,dmuxout)
end process;
end xxx;
The errors are:
Illegal expression
xx.vhd, 40
yyy
  with rdptr select
  Expression must be the name of an object whose subtype is locally static, or
  it must be a qualified expression or type conversion whose type mark denotes
  a locally static subtype.
Illegal expression
xx.vhd, 40
yyy
  with wrptr select
: Edited by User
The with-select is a concurrent statement. It cannot be used inside a
process. Use the case-when instead...
Author: Ayush Khemka (Guest)
I did put it outside the process. It can be seen in the code clearly.
Ok, I see. But then the problem is not in the posted code.
Where does n come from?
  • [vhdl]VHDL code[/vhdl]
