Forum: FPGA, VHDL & Verilog VHDL MODEL FOR SINGLE D-TYPE LATCH WITH 3-STATE OUTPUT
Author: Naija Coding (Company: Student) (naijacoding)
Hello all. I'm new to VHDL programming so please forgive me in advance
if i ask any bad question. I have an assignment to create a VHDL model
and testbench for SINGLE D-TYPE LATCH WITH 3-STATE OUTPUT device. I have
started reading up as much as i can and time is running out. Could i get
ideas, advice or any help on this topic? thanks
Naija Coding wrote:
> I have an assignment to create a VHDL model and testbench for SINGLE
Of course this is just a 10-minute job for a VHDL expert, but YOU got
the excersise from your teacher. So, show what YOU have (at least you
should have thought about it and written a few lines of code), then WE
can discuss it. But no one here is intended to do your homework
completely.
> I have started reading up as much as i can and time is running out.
You cannot learn by reading. You must learn by doing. Install one of the
free toolchains (eg. from Altera, Lattice, Xilinx) on your PC and start
working with it...
i have installed xilinx 14.1. Attached is what i have tried so far.
Sorry it's my first time so still getting used to it. Any further help
or advice? Am still working on it and my deadline is in 5 days
Pls post the code again. Simply copy it this way into your post:
[vhdl]
   your VHDL code
[/vhdl]
Then everybody can copy and edit it...
> Any further help or advice?
Whats the problem with this code? Do you get error messages? Or is there
strange behaviour in the simulation with your testbench (which you
didn't post up to now)?
I'm missing LE in the code. and I would split up the whole thing in two
steps with a internal signal:
1. depending on LE latch the input to a internal signal
2. depending on OE switch either this internal signal or 'Z' to the
output
You took 2 steps in 1 and began to stumble
Then you must speed up a little bit. Your initial post was 4 days ago...
  • [vhdl]VHDL code[/vhdl]
