Forum: FPGA, VHDL & Verilog Using the Xilinx ISE Design Suite 14.7 version
Author: Juan (Guest)
I am using a Xilinx Spartan 3E-100 Basys2 module in order to make a
design corresponding to a dynamic display circuit into the ISE design
suite program (14.7 version), however when generating the program file,
when I start to make a synthesis of the main program and its modules it
returns me two errors and It says that one of them corresponds to the
part of implementation of design, and the other to the translation of
the program. If someone could help me find out why this happens or what
would be the typical reasons why such errors occur, it would be really
helpful.
Author: Björn Punkt (bjrn_g)
Can you reply the error code please?!
It is impossible so make a remote diagnostics without knowing the full
project or the error code.
Which one? What do you see on the "Errors" tab?
Yes, the one that is on the "Errors" tab. Also the ones that are
highlighted on the image.
Author: please (Guest)
klick on the Error tab, so everyone (including you) sees the actual
error description.
And maybe you first work through some ISE Tutorials sometime...
Forgive me for the response again, well about the error it actually
says:
"#3/Dinamico/dinamico.ucf(22)]: NET "btn<3>" not found. Please verify
that: 1. The specified design element actually exists in the original
design. 2. The specified object is spelled correctly in the constraint
source file".
Juan,
Obviously you're lacking fundamental knowledge of FPGA development. You
should find Demo-Projects for your Xilinx Spartan 3E-100 Basys2 module
and use these to learn what's going on in .ucf files, during Synthesize,
Translate, Map, Place&Route,...
Your (current) error is, that your .ucf file tries to constrain a signal
called btn<3> (probably to a PIN location or maybe a timing net). But
such a signal (wire) does not occur in your code (i.e. input/output
list)
  • [vhdl]VHDL code[/vhdl]
