Forum: µC & Digital Electronics AVR - ATmega8A - External Interrupt - Sometimes odd behaviour
von Alex K. (Company: ---) (akap)
I am currently working on a MCU unit which will respond to external
interrupts in order to perform specific tasks. The controller I am
using: ATmega8A.
The external interrupt is defined as followed:
PORTD |= 0x04;                //Activate pull up resistor of PD2
GICR |= (1 << INT0);          //Enable INT0
MCUCR |= (1<<ISC00);          //INT0 is executed on every edge
The ISR:
ISR (INT0_vect)
                /* interrupt code here */
                v = 1;          //sets interrupt variable v to 1
The variable v is defined as : volatile int v.
 volatile int v = 0;
I am currently testing the behavior of the external interrupts. Whenever
an external interrupt is detected a particular code block should be
executed. The interrupt is applied to the INT0 by any logic change.
 ISR (INT0_vect)
 int main(void)
    USART_Init();
    I2C_init();
    //int a;                      //test variable
    sei();
    unsigned char a;
    a = USART_Receive();
 while(1)
        //TODO:: Please write your application code
        do
        } while (v == 0);     //Wait for interrupt
        v = 0;
        _delay_ms(10000);
  //Communication protocol between MCU unit and GUI software application
            //Block 1
            USART_Transmit(0xFF);                           //Header start command
            USART_Transmit(0x00);
            USART_Transmit(0x08);
            USART_Transmit(0x09);
            USART_Transmit(0x02);
            USART_Transmit(0x04);
            USART_Transmit(0x05);
            USART_Transmit(0x06);
            USART_Transmit(0xFE);                           //Header finish command
            do
            v = 0;
        _delay_ms(10000);
 //Block 2
            USART_Transmit(0x01);
     return 0;
[c]
Testing the code, I can say that the interrupts are recognized and the
code is functioning. However, it seems that there is a little bug or
logic error. When the first interrupt occurs (before block 1), block 1
is supposed to be executed. Now, if the second interrupt occurs, the 2nd
block should be executed.
I can see this execution sequence in a pre-written GUI application,
however, most of the time block 1 (when applying the interrupt) is
executed many times after another and than block 2.
It should always be the following sequence: block 1 than block 2 and so
on. I think that this is a timing issue. But I cannot debug this
problem.
I am also wondering if there is a code in C that tells the program to
wait for an external interrupt signal and than continues the program?
Thank you very much in advance.
von Marc Vesely (Guest)
> problem.
Is this now your complete code ( Except diverse #include etc.) ?
ISR (INT0_vect)
 volatile int v = 0;
 int main(void)
    USART_Init();
    I2C_init();
    sei();
    unsigned char a;
 while(1)
        do
        { } while (v == 0);     //Wait for interrupt
        v = 0;
        _delay_ms(10000);
  //Block 1
30
31
32
33
34
35
36
37
38
39
40
        do
41
42
        v = 0;
43
        _delay_ms(10000);
44
 //Block 2
45
46
47
48
49
50
51
52
53
54
55
56
57
58
     return 0;
59
 If so, pls. post as such and not as bedsheet with unnecessary
 empty lines.
 Do you have TxBuffer ?
von Martin (Guest)
Try to use this instead of the _delay_ms(10000):
for (uint16_t i=0; i<=10000) _delay_ms(1);
The maximal possible delay is 262.14 ms / F_CPU in MHz.
When the user request delay which exceed the maximum possible one,
_delay_ms() provides a decreased resolution functionality. In this mode
_delay_ms() will work with a resolution of 1/10 ms, providing delays up
to 6.5535 seconds (independent from CPU frequency). The user will not be
informed about decreased resolution.
von Martin (Guest)
for (uint16_t i=0; i<=10000; i++) _delay_ms(1);
