Forum: FPGA, VHDL & Verilog VHDL code to implement a SATA disk controller on a Virtex 5 FPGA
von Sunayana C. (sunayana_c)
Hello All,
I am new to designing a VHDL code for a SATA device. I would like to get
a few VHDL examples to design the same. Can someone help?
Then start with the flashing LED, the chasing light, RS232, VGA and so
on. And half a year later you will be able to do bigger steps...
But you will never get the thing running just by copying some code grime
somewhere without knowing a thing about hardware.
> for a SATA device.
What hardware (FPGA, ASIC)?
What kind of device?
I will be using FPGA Virtex 5. I am not copying fyi. I just need some
examples on how to go about this entire process. Please help if you can
One thing is sure: with no knowledge in VHDL and FPGA you will not be
able to do the SATA core from scratch the next half year (at least!).
What is your time schedule for this task?
Do you have the money to use a commercial and proved SATA IP core?
I have experience working on VHDL and FPGA. I have worked on it for an
year now. I am new to SATA controller. I read through the basics of
SATA. I now need to know how to write an FPGA code for the same. Please
provide some examples for the same.
von blablablub (Guest)
what examples do you need? SATA is a big and complex protocol. You have
to consider several levels of protocols.
The first questions is not, if you read the full specification, the
question is how often you read it?
Then you have to find out the lowest level protocol. Often called as
physical layer coding or line coding. This is the first step to
implement.
Then you have to go step by step.
You wrote you have experience in FPGA. Do you also have experience with
gigabit transceivers? If not, than spend the next month only in
designing and working with this transceivers. There are a lot of
pitfalls ...
A simple example code for SATA won't be available, because it is too
complex. If you don't know how to start, then search for another project
you can do, where you can collect more experience ...
Cheers
