Forum: FPGA, VHDL & Verilog accurate counter
Author: Mohammad Mothermohammad (mohammadmother)
hi every body
i write a vhdl code that is nearly accurate counter
every 1.34 s the LED will be ++
(2^27*10ns = 1.34 s )
please tell me what is it's problem because in ISIM i don't got the
answer
-- Company:
-- Engineer:
-- Create Date:    08:48:18 09/28/2014
-- Design Name:
-- Module Name:    count - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.STD_logic_unsigned.ALL;
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity count is
    Port ( clk : in  STD_LOGIC;
           reset : in  STD_LOGIC;
           sw1 : in  STD_LOGIC;
           LED : out std_logic_vector(7 downto 0));
end count;
architecture Behavioral of count is
begin
process (clk,reset,sw1)
variable c :std_logic_vector(7 downto 0):="00000000";
variable counter :std_logic_vector(27 downto 0):="0000000000000000000000000000";
begin
   if reset='1' then
        LED <= "00000000";
     elsif sw1='1' then
         LED <= "11111111";
     elsif(clk'event and clk='1') then
       counter := counter +1 ;
          if (counter ="1000000000000000000000000000") then
                c:=c+1;
                LED<=c;
             counter:="0000000000000000000000000000";
        end if;
    end if;
end process;
end Behavioral;
: Edited by Moderator
Author: asd (Guest)
just some tipps:
- no need to use variables here, use signals instead for the counting
logic. (and read about the difference of signals and variables)
- it's better style to use IEEE.NUMERIC_STD.ALL to calculate in vhdl and
don't calculate with logic_vectors directly, but instead with integer or
natural
- you can use hex-format for more compact style: x"00" for "00000000"
First: please use the vhdl tags areund your VHDL code:
[vhdl]VHDL code[/vhdl]
Then this:
Why do you use a variable?
Why don't you use an integer?
And where did you find this:
   if reset='1' then
      LED <= "00000000";
   elsif sw1='1' then
      LED <= "11111111";
An asynchronous reset AND additionally a conbinatorial reset. Thats
plain rubbish!
This here:
Could be shortened to that:
counter:=(others=>'0');
My VHDL code usually is exactly accurate. Whats the problem with
yours?
> please tell me what is it's problem because in ISIM i don't got the answer
What error messages do you get? What do you expect and what happens
instead?
I would do it like this:
library IEEE;
entity BlinkLED is
           led : out  STD_LOGIC);
end BlinkLED;
architecture Behavioral of BlinkLED is
                                                    -- let the synthesizer do the hard work!
signal c : integer range 0 to 1340000000/10-1 := 0; -- 1.34s at 100MHz = 1340000000ns/10ns
signal x : std_logic:= '0';
begin
   process begin
      wait until rising_edge(clk); -- wait till next clock
      if (c<1340000000/10-1) then  -- check the counter
          c <= c+1;                -- if less: count up
      else                         -- if reached:
          c <= 0;                  -- reset counter
          x <= not x;              -- and toggle the local signal x
      end if;
   end process;
   led <= x;                       -- hand x over to the LED
end Behavioral;
thank you for every one i modified the code and implement this into FPGA
and it's work.
correct code is:
-- Company:
-- Engineer:
-- Design Name:
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
library IEEE;
--library UNISIM;
entity count is
           sw1 : in  STD_LOGIC;
end count;
begin
variable counter :std_logic_vector(26 downto 0):="000000000000000000000000000";
begin
      if reset='1' then
         LED <= "00000000";
          counter := "000000000000000000000000000";
       c:="00000000";
     elsif sw1='1' then
         LED <= "11111111";
          c := "11111111";
       LED <=c;
      -- for i in 0 to 10000000 loop
           --      if (i=10000000) then
         --      counter:="000000000000000000000000000";
             --    c:="00000000";
              --  LED <= c;
             --end if;
              --  end loop  ;
         else
           if (counter ="101111101011110000100000000") then
                c:=c+1;
                LED<=c;
            end if;
     end if;
end if;
end process;
end Behavioral;
: Edited by User
  • [vhdl]VHDL code[/vhdl]
