Forum: FPGA, VHDL & Verilog Calculate Sum of (z[n])^2 in VHDL
von Eric T. (madz)
I want to calculate the Sum of (z[n])^2 in VHDL. If the signal z is
represented in 2's complement with b bits and I want to calculate the
power of groups of N samples!
Thank you!:)
: Edited by User
> If the signal z is represented in 2's complement with b bits.
And what's the problem with that?
What is z? What n? Where do they come from?
von Eric T. (madz)
Z is just the outsignal and n is the groups of samples(forgot to write
it so edited my first post)
And the problem is I need help to code this.
von Colibri (Guest)
This is not a VHDL issue. What you first need is a concept of a circuit.
You have to use a counter, start stop conditions, a resetable
accumulator and somewhere a multiplier. If you do not see the circuit
required, FPGA is not your business
And where are they located? Where and how do the "samples" come from?
Are they already stored in a RAM? Or is one sample generated each clock?
What hardware do you have? Or is it just for simulation?
The actual problem is, that VHDL is a hardware description language.
And to describe somthing you must have a "picture" or some imagination
of your target hardware. Do you?
