Forum: FPGA, VHDL & Verilog Communication system: Interleaver
Author: Rob Griffin (neverbackdown)
Hey! I have been stuck on this exercise for a few days and i have
realized that i wont make it on my own. So i decided to ask here for
help! :)
 In a Communication system we want to interleave four inputs signals,
a,b,c and d coming from different antennas, ( See the attached picture).
Each input provides a valid data every four clock cycles. This is
indicated by a data_temp input. This signal is used as a control signal
and its value is ‘1’ during one clock cycle every four clock cycles.
a)  Design(draw) a circuit that interleaves the four inputs signals.
Distinguish between the path for data and the control logic. You do not
need to specify the word lenth of the signals unless it is relevant for
understanding the circuit.
Does "wont" mean "want" or "won't". Both cases are possible...
> Design (draw) a circuit that interleaves the four inputs signals.
What part of this particular task is related to FPGA or Verilog or VHDL?
Look for components named "serializer" or "parallel to serial
converter".
> So i decided to ask here for help! :)
And whats the question? Where's your problem? How much of your homework
did you do already?
> converter".
> did you do already?
I meant "won't" I'm sorry for that. My question is
"Design(draw) a circuit that interleaves the four inputs signals.
understanding the circuit."
And yes it is related to FPGA and VHDL because when I have my circuit i
will code it in VHDL then program it on my FPGA.
Author: clarification bear (Guest)
You will need a multipexer at 4 times the speed of the incoming data, a
data buffer, since all the 4 signals seem to occur simultaneously and a
counter controlling the multiplexer address, being syched with the
buffer enable
Rob Griffin wrote:
> My question is
Isn't a question that thing with an question mark at its end?
However: did you do a little google search for the keywords I gave you?
And did you do a look for e.g. the 74165? Or have a look for the inside
schematic of this serializer:
http://www.micrel.com/index.php/en/products/clock-...
Indeed this task here is in no way related to any HDL. Its pure
analyzing and schematic...
: Edited by Moderator
Okey guys so i made this circuit, is it right?
Author: uwe (Guest)
Author: uwe (Guest)
If A B C D and Z have more bits you need a multiplexer and a counter to
control the multiplexer.
It tends to the right direction, but: who controls the four
multiplexers?
And: the bit order of your circiut is dcba, not abcd as demanded.
  • [vhdl]VHDL code[/vhdl]
