Forum: FPGA, VHDL & Verilog VHDL code help (beginner level)
Author: Omar (Guest)
This is my code (to design Carry Look Ahead Adder)
library ieee;
use ieee.std_logic_1164.all;
entity CLAdder is
  port(A,B: IN std_logic;
    Cin: IN std_logic;
    Sum: OUT std_logic_vector(3 DOWNTO 0);
    Cout,G,P: OUT std_logic);
end CLAdder;
architecture behavior of CLAdder is
  signal carryGen: std_logic_vector(3 DOWNTO 0);
  signal carryProp: std_logic_vector(3 DOWNTO 0);
  signal Sumation: std_logic_vector(3 DOWNTO 0);
  signal carryIns: std_logic_vector(3 DOWNTO 0);
begin -- behavior
    Sumation(0) <= A(0) xor B(0) xor Cin;
    carryGen(0) <= A(0) and B(0);
    carryProp(0) <= A(0) or B(0);
    carryIns(0) <= carryGen(0) or (carryProp(0) and Cin);
    Sumation(1) <= A(1) xor B(1) xor carryIns(0);
    carryGen(1) <= A(1) and B(1);
    carryProp(1) <= A(1) or B(1);
    carryIns(1) <= carryGen(1) or (carryProp(1) and carryIns(0));
    Sumation(2) <= A(2) xor B(2) xor CarryIns(1);
    carryGen(2) <= A(2) and B(2);
    carryProp(2) <= A(2) or B(2);
    carryIns(2) <= carryGen(2) or (carryProp(2) and carryIns(1));
    Sumation(3) <= A(3) xor B(3) xor CarryIns(2);
    carryGen(3) <= A(3) and B(3);
    carryProp(3) <= A(3) or B(3);
    carryIns(3) <= carryGen(3) or (carryProp(3) and carryIns(2));
    G <= carryGen(3) or (carryGen(2) and carryProp(3)) or (carryGen(1)
and carryProp(2) and carryProp(3)) or (carryGen(0) and carryProp(1) and
carryProp(2) and carryProp(3));
    P <= carryProp(0) and carryProp(1) and carryProp(2) and
carryProp(3);
end behavior;
When using vhdlan to verify and check for errors I get 24 errors at each
of the signal assignments in the behavior body going like
Error-[OVBADAPPLIED] Illegal prefix
CLAdder.vhd, 36
BEHAVIOR
  Prefix of name cannot be interpreted as a subprogram or array.
This is just one of them. The rest are all the same but for different
assignments. I cannot figure out what is wrong here. Please help.
: Locked by Moderator
A and B should be 4-bit vectors...
: Edited by Moderator
Author: Colibri (Guest)
They are, aren't they?
Author: Schlumpf (Guest)
No they aren´t
right, don't know how I overlooked that
Author: REKHA V P (Company: college of engineering chengan) (rekhavp)
I have written a VHDL code for a number of cascaded mux stages. During
simulation it is observed that the syntax is succesfull and RTL
schematic is generated. But I can't implement the test bench waveform.
I'm attaching the code with this. Also attaching the generated RTL
scheatic.
Start a NEW thread for a NEW question!
And post VHDL code as *.vhdl file.
And don't use all the libraries you can find in the universe in one VHDL
module:
use IEEE.STD_LOGIC_ARITH.ALL;      --- never
use IEEE.STD_LOGIC_UNSIGNED.ALL;   --- ever
use IEEE.numeric_std.all;          --- use those three together!
What problems do you encounter?
This topic is locked and can not be replied to.
