Forum: FPGA, VHDL & Verilog Comparator 2 Bit Question
von AOG (Guest)
Hello to Everybody
Well im new in VHDL so maybe this is a really easy question for some
people in here i need to do a 2 bit Comparator in Behaviour
mi Design vhdl is like this:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity comparator_2bit is
     port(
         A : in STD_LOGIC_VECTOR(1 downto 0);
         B : in STD_LOGIC_VECTOR(1 downto 0);
         Igual : out STD_LOGIC;
         Mayor : out STD_LOGIC;
         Menor : out STD_LOGIC
end comparator_2bit;
architecture comparator_2bit_arc of comparator_2bit is
begin
    Igual <= '1' when (a=b) else //EQUALS
             '0';
    Mayor <= '1' when (a<b) else //GRETER
               '0';
    Menor <= '1' when (a>b) else //LOWER
             '0';
end comparator_2bit_arc;
But my question is i don't know how to do the Testbench because i tried
doing something like this but when i try to compile i have a lot of
errors
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
port (
architecture Behavioral of comparator_2bit is
begin
process(a,b)
begin
    A <= '1';
    B <= '1';
    wait for 1 ns;
    assert(Igual='1') report "Fail 1/1" severity error;
    -- Clear inputs
    A <= '0';
    B <= '0';
end process;
end Behavioral;
So please can you help me Im new in VHDL :/
von Dussel (Guest)
Spanish or portuguese VDHL? Sound funny when I read the code in my mind
:-D
First thing I see is that you use wrong comment style. Comments in VHDL
are initiated with -- instead of //.
What is the second code supposed to do? The name suggests that it is
another form of the comparator, but it only assigns values to the
inputs, which is not allowed and does not make sense in this context.
It would help, if you tell us which errors you get.
von AOG (Guest)
Hey Dussel! Thanks for your reply well those comments with // was only
in this text edit but well i start moving my code and now it compiles
but when i see the simulation A and B marks me with "X" when in the
Testbench im putting 1 or 0
Show you my code:
DESIGN:
library IEEE;
     port(
         A : in std_logic;
         B : in std_logic;
begin
             '0';
               '0';
             '0';
TESTBENCH:
library IEEE;
use IEEE.std_logic_1164.all;
entity comparator2bit_TB is
end comparator2bit_TB;
architecture comparator2bit_TB of comparator2bit_TB is
component comparator_2bit is
port(
      A : in std_logic;
         B : in std_logic;
         Menor : out STD_LOGIC);
end component;
signal A,B: std_logic;
signal Igual,Mayor,Menor:std_logic;
begin
DUT: comparator_2bit port map (A,B,Igual,Mayor,Menor);
process
begin
A<='1';
B<='1';
wait for 1 ns;
assert(Igual='1') report "Failed en 0000+0000+0" severity error;
end process;
WHEN I SEE THE SIMULATION SHOWS ME THIS
von Dussel (Guest)
Sorry, I can not see what's wrong.
What happens if you initialise A and B with different values, for
example A=0, B=1?
My guess is, that your simulator does not run your testbench but your
comparator as simulation entity. The A and B are not initialised in the
entity so they have the state 'X'. Then they are bot equal and your
comparator outputs Igual.
von AOG (Guest)
You were right Dussel Thanks the simulator was running the Design not
the testbench thank you so much :)
