Forum: FPGA, VHDL & Verilog Time Stamping on a Nano second scale
Author: Wadood S. (wadood_s)
Hello!
I'm making a coincidence counter for an optics experiment.
So currently the problem is this:
An event of interest occurs at a frequency of 6-7KHz. This is in the
form of 50ns pulses. I need to 'time-stamp' these events i.e. at what
time they occured, on a discrete time scale with resolution of 1ns.
(based on the rising edge)
The simple approach I'm trying here is to run a timer with a 1GHz clock
and whenever the event occurs, save the timer value.So the external
clock needs to be of time period 1ns.
So can FPGA timers run on the 1GHz processor clock? Or do they run on a
slower clock?
Another problem would be the time taken to latch the value of the timer
to a storage register. Does it take many clock cycles(and which clock)
or does the latching occur in an analog fashion(on order of
picoseconds)?
I'm also not an expert on FPGAs and have just worked on
Micro-controllers previously.
So is this task do-able on FPGAs? And what FPGAs would be suggestable?
Regards
Abdul Wadood
Author: Lattice User (Guest)
> slower clock?
The FPGA don't have timers out of the box, you have to build them using
the FPGA logic resources. But with most FPGAs you will by far not
achieve 1 GHz.
> picoseconds)?
> Regards
The task is do-able, but not with just a counter. It is possible to
exploit the high speed IO Capabilities of a modern FPGA to use a much
slower clock. The 1 ns should be doable on normal IOs of an actual FPGA
like Spartan6, Cyclone V, ECP3. With a GT Serdes a higher resoltuion may
be possible, mabye even 50ps on an Aria 10.
But this tricks require a lot FPGA experience with high speed IO. In
other words get an expert.
Author: zoggl (Guest)
Time to digital converters with multi hit could do that,depending on the
amount of hits.
I've looked into TDC's. MAX35101, Gp-22, and THS766. I want to use them
with a micro-controller(or even an fpga) but they don't give out an
evaluation boards. My budget is under 400 USD.
Googling '1GHz fpga' returns a virtex 7 fpga or a Xilinx-7000.
Wouldn't these things work?
@Lattice User: What technique are you actually suggesting? Is it the
clock interpolating technique used by TDCs?
That search term is to unspecific to return useful results. In many
FPGAs are subsystems which can go beyond 1 GHz, in case of Xilinx Zynq
7000, this
is probably the ARM core. To build things like counters with the fpga
you need a FPGA core clock with 1 GHz. The fastet FPGA in the making
(according to Altera) is the Stratix 10, and will achieve according to
one source clockrates from 500 - 1000 NHz. Another source put it at
about 750 MHz. The Stratix 10 is build with Intels 14 nm trigate process
and amples are planned for next year.
I haven't looked at TDCs for a long time, so i don't know.
Many FPGAs have IO blocks, which can do at least DDR clocking, that
means sampling the signal at both clock edges. This doubles the
resolution. Some can do even more using phase shiftet clocks, mainly x4
but x8 is also available in some devices.
With x4 you will get 4 bits with your "slow" clock depending on the
arrival of the pulse in relation to the clock this will be, 1111, 0111,
0011, 0001. Enocde these to 2 bits and append it to the captured counter
value.
It is also doable with an external delay line and using multiple inputs.
The price you pay is an unknown differential error of some 100 ps.
Author: Michael (Guest)
Hello
The ISERDES in a SPARTAN 6 can run at 1050 MHz. 8:1 Radio. LVDS Inputs.
In a Series 7 FPGA it shut be faster.
MfG
Michael
Author: berndl (Guest)
you may try google with the keyword 'flancter'. Then find out if your
FPGA is fast enough for your problem...
Author: Jürgen Schuhmacher (engineer)
You do not need to run the FPGA at a system speed of 1GhH just because
of the fact, the time base has to be that precise. Think of parallel
structures to create virtual time bases from the given inputs.
With time trained inputs it is possible to achieve an accuracy of 100ps
and better using common IO-Delay functionality.
  • [vhdl]VHDL code[/vhdl]
