Forum: FPGA, VHDL & Verilog Verilog Code Help
von Navtej J. (Company: RMIT) (johal_navtej)
Hi
Is there anyone on this forum who can help me write a verilog program
for a stopwatch. I need it within the next two days to pass my subject.
I am attaching the problem sheet. This is a completely new language for
me and if anyone out there can help it would be much appreciated.
I need  to design a stopwatch with three input buttons
button1:start/stop
button2:reset
button3:lap
And n display output of hh mm ss(hours minutes seconds)
hours go from 0-99
minutes 0-59
seconds 0-59
Thats not the way things work here!
Let's try it the other way: you show us what you have and tell us about
particular problems. THEN we can discuss that problems. But no one is
intended to do your homework (which you have laying around at least
days...).
BTW: did you read the last sentence on that sheet?
And: Did you try Google?
http://www.google.com/search?q=stop+watch+verilog
von Pratik K. (Company: Rv-VLSI) (pratik_sk)
Hey hello,
I have a problem here!
A am designing 4:1 mux using 2:1 (Structural).
In 2:1 mux I have written like this,
module mux2to1(y,i,s);
input [1:0] i;
I am using this as a instance in 4:1 prog,
where I am giving inputs as
wire sig1,sig2;
mux2to1 u1(y,sig1,sig2,s0);
Error is : Too many port connections. Expected 3, found 4.
It means thing is that 'i' input in mux 2:1 is recognized as a single
input by software though I am defining it [1:0] in next line..
Is there any different solution available ?
Or I simply have to do like mux2to1(y,i0,i1,s);
von Lattice User (Guest)
> input [1:0] i;
> wire sig1,sig2;
mux2to1 u1(y, {sig1,sig2}, s0);
von Prasanna M. (prasanna_m)
please help me to write the verilog program for this.
There is the first step to the solution:
http://embdev.net/topic/342471#3775885
BTW: did you read the thread in front of you?
I am very sure you did not! Because the very SAME exercise and question
can be found in the FIRST post of this thread!
