Forum: FPGA, VHDL & Verilog remains a black-box since it has no binding entity
von Kim (Guest)
Hello, I have a problem programming vhdl. The  message I am getting is
HDLCompiler:89 remains a black-box since it has no binding entity.
How can this issue be solved?
Thanks for your help.
No answer is possible because your code (that one producing the error)
is not attached...
von kim (Guest)
Hi this is the code I am having problems with...
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library work;
use work.convert_pack.all;
entity test is
    Port (
   clk_o : out  STD_LOGIC;
   output : inout std_logic;
   clk : inout std_logic;
   index : inout std_logic_vector(6 downto 0)
end test;
architecture rtl of test is
    component ntest
        PORT(
     output  : out std_logic;
     clk : in std_logic;
    index : in  std_logic_vector(6 downto 0)
    END COMPONENT;
30
BEGIN
31
32
   bla: ntest
33
  PORT MAP (
34
  clk => clk,
35
  index  => index,
36
  output => output
37
38
39
40
   clk_process :process(clk, index, output)
41
   begin
42
43
44
  clk <= not(clk);
45
46
  if (rising_edge(clk) and clk = '1') then
47
  index <= u2slv(slv2u(index)+1);
48
  end if;
49
50
  if  slv2u(index)= 89 and output = '1'then --
51
  index <= (others => '0');
52
  output <='0';
53
  end if;
54
55
  if  slv2u(index) = 34 and output = '0'then --
56
57
  output <='1';
58
  end if;
59
60
clk_o <= output;
61
62
end process;
63
64
65
66
end rtl;
: Edited by Moderator
Pls use the VHDL tags. How to use them? Its in the edit box for the text
input:
    Post long source code as attachment, not in the text
    Posting advertisements is forbidden.
    [vhdl]VHDL code[/vhdl]
This is a VERY unusual way to generate a "clock":
 begin
  clk <= not(clk);
Where did you find such a piece of code? Is it your own? How do others
generate a clock? Why do they do it much different?
Wheres the entity of ntest? Is it included to the project?
von sia (Guest)
what does this error mean ?
An entity is missing in the project files list.
What particular error in conjunction with what design?
