Forum: FPGA, VHDL & Verilog Illegal recursive instantiation
von Iluvatar (Guest)
Hi guys,
I am having problems with my program and wonder if anyone can help me
out.
The errormessage i am getting is:
ERROR:HDLCompiler:1171 - Line 30: Illegal recursive instantiation of
test(rtl)
does anyone know how to solve this?
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_SIGNED.ALL;
library work;
use work.convert_pack.all;
entity test is --line 30
    Port (
   clk_o : out  STD_LOGIC;
   output : inout std_logic;
   clk : inout std_logic;
   index : inout  std_logic_vector(0 downto 0)
end test;
architecture rtl of test is
    component test
        PORT(
     output  : out std_logic;
     clk : in std_logic;
    index : in  std_logic_vector(0 downto 0)
    END COMPONENT;
BEGIN
   bla: test
  PORT MAP (
  clk => clk,
  index  => index,
  output => output
   clk_process :process(clk, index, output)
   begin
  clk <= not(clk);
  if (rising_edge(clk) and clk = '1') then
  index <= u2slv(slv2u(index)+1);
  end if;
  if  index = 89 and output = '1'then --
  index <= (others => '0');
  output <='0';
  end if;
  if  index = 34 and output = '0'then --
  output <='1';
  end if;
clk_o <= output;
end process;
end rtl;
PS: I am working on a Spartan-6 Atlys Board in case this information is
needed.
von Tobias L. (murxwitz)
Your Toplevel Entity and the component you try to instantiate are both
named test, so you have to rename one
library ieee;
library work;
entity test_top is --line 30
    Port (
end test_top;
architecture rtl of test_top is
    component test
        PORT(
     clk : in std_logic;
    END COMPONENT;
30
31
32
BEGIN
33
34
   bla: test
35
  PORT MAP (
36
  clk => clk,
37
  index  => index,
38
  output => output
39
40
41
42
43
   begin
44
45
46
  clk <= not(clk);
47
48
49
50
  end if;
51
52
53
54
  output <='0';
55
  end if;
56
57
58
59
  output <='1';
60
  end if;
61
62
clk_o <= output;
63
64
end process;
65
66
end rtl;
should work (not tested)
PS: don't use the obsolete
: Edited by User
thanks for the hint, i got now this error message:
Line 71: found '0' definitions of operator "=", cannot determine exact
overloaded matching definition for "="
library ieee;
library work;
entity test is
    Port (
end test;
    component ntest
        PORT(
     clk : in std_logic;
    END COMPONENT;
BEGIN
   bla: ntest
  PORT MAP (
  clk => clk,
  index  => index,
  output => output
   begin
  clk <= not(clk);
  end if;
  if  index = 89 and output = '1'then --line 71
  output <='0';
  end if;
  output <='1';
  end if;
clk_o <= output;
end process;
end rtl;
Pls use the VHDL tags (to be found in the "Formatting options" a few
lines under "Reply Rules — please read before posting")!
  if index = 89 and output = '1' then
VHDL has a very strict data type handling. You cannot compare a vector
with an integer. Those two are COMPLETELY different. And therefore the
operator '=' don't "know" hao to handle those two operands.
Two solutions:
1. You must compare the same data types
2. you must overload the '=' funktion (yes, its only a function in VHDL)
This here is a stupid lazy "trick":
Every beginner thinks to be neat defining ports as inout to read them
"back". But this is the most easy way to dig holes in the structure of a
VHDL description. Beeing your boss or your teacher I would degrade you
for that...  :-o
