Forum: FPGA, VHDL & Verilog Need help to choose FPGA
Author: MAINUL ALAM (Company: Master student) (mainul)
I want to buy a FPGA evaluation kit for my project. I have to do an
image processing task with it.
More specifically, The FPGA will take input from a 5 Mpix camera and it
will discard the unnecessary data from the image and store the necessary
data. Algorithm for choosing necessary/unnecessary data also should be
develop able in the FPGA.
Can Any body please help me which one should i choose for this task ...?
If possible please let me know the reason behind your suggestions also..
How do you define "necessary" and "unnecessary"?
Usually the easier way for image manipulation is to develop an algorithm
on a PC. And when the algorithm works you transfer it to a FPGA to speed
it up. Do you have that algorithm already? Because without knowledge
about that particular algorithm you must use the biggest FPGA...
Sorry, we didnt develop the algorithm yet ... bur first of all we have
to choose a FPGA for the task ... can you please help us regarding that
Author: nerved (Guest)
Please consider the daterate of the cam, not the resolution.
First take a look on the datasheet of the cam, resoltion is 5meg so far,
but whar about the framerate and the colourdeepth? What kind of
interface will you need for the cam?
Search for some papers to calculate the memorybandwidth for
video-applications on FPGA-Systems (think about how many cycles you need
for your algorithm).
If you cants do this yet, it is not guaranteed, that your developmentkit
ist capable to do your application, but i think an cheap videokit will
do it, like this:
http://www.terasic.com.tw/cgi-bin/page/archive.pl?...
You put the cart before the horse! When you don't know how your
algorithm looks like you cannot select a FPGA.
Or lets say it otherwise: choose the biggest FPGA you can get. Then
start development of your algorithm. And if it fits in the big FPGA (for
which to buy you don't have the money) then it may fit in a smaller FPGA
also.
Where do the pictures come from? How fast do they come?
> also.
He is a student, wich means money matters and a 5k$+ board is way to
much.
In most cases you can compensate money by brain. This is the case here!
@MAINUL ALAM
So: first think and specify the demand. Then choose the hardware.
Especially in picture processing the WHOLE development can be done
independent from hardware eg on the PC you're browsing now. Just take
the picture or a sequence of pictures and evaluate the algorithm. This
will not work in real time, but when the algorithm is finished, THEN its
time to talk about hardware to speed it up.
: Edited by Moderator
Let me explain my situation ... actually i am doing my master project
now and devolping the algorithm using vhdl or verilog will be a task of
master thesis ... which i am not sure whether i will do on it or not ...
so at this moment my concern is choosing the fpga only ... regarding the
camera i have only the information that it will be a 5 Mpix camera ...
And why we usinng FPGA instead of doing this using computer ? ans is in
future there might be some additional task include in the system and
then this FPGA will be a very useful unit... and also the task has to be
very fast thats why FPGA
MAINUL ALAM wrote:
> ans is in future there might be some additional task include in the
> system and then this FPGA will be a very useful unit
Geht the biggest FPGA you can geht for the bucks. Also add some kind of
fast memory to it.
Its way far easier to do the evaluation on a PC.
> regarding the camera i have only the information that it will be a 5
> Mpix camera
How will it be connected to the FPGA?
> has to be very fast
What is fast? Technical dimensions would be helpful...
> actually i am doing my master project now and devolping the algorithm
> using vhdl or verilog will be a task of master thesis ... which i am not
Just my opinion: if you never did anything into deep with FPGA up to now
(and it sounds like that!), then choose a different master thesis. You
will need much more than those 4 months to get the things running...
thanks for your suggestions.
i just got the information about the camera from my professor. following
is the camera we will use :
http://de.ids-imaging.com/store/ui-3240ml.html
Regarding the algorithm :
The task of the algorithm is
-          To extract pixel positions, were we do have a signal of our
recorded circle and transmit this intensity signals only
-          to calculated the diameter of the circle
-          to calculate the width of the circle for e.g. every degree of
the circle (from 0° to 360°)
-          maybe you do have an additional idea
PLEASE SUGGEST ME A FPGA IF THIS INFORMATION IS ENOUGH ....
That's an USB camera. How do you connect to it? Will you have to
implement a USB host also?
Author: Lattice User (Guest)
Hmm,
This is an USB3 Camera, you can't easily interface it to a FPGA.
Actually it is very very difficult.
Extracting the sensor module may be possible, but then you are without
documentation.
OK, now we have some informations....
First: You recognized, that the cam has only a resoltuin of 1280 x 1024
pixel, wich is 1.3 megapixels? (not 5 as you told in yout opening post).
I think its ok for your application. just wondering....
depends on the type, you will get an RGB or BW cam (i guess its BW),
1280*1024*60 frames @ 12 Bit resoltion requries at least 2 GBit/s memory
bandwidth for your framebuffer, wich is usually no problem for common
FPGA-boards with DDR2 or DDR3 memory.
The manufaturer is a good choice, perhaps you can even get some
technical support from.
You have two really big problems with this task:
1. You will have to find an FPGA-Board with an USB 3.0 Interface, then
you will have to write an USB-Driver for the cam, and you dont have any
informations how to do this. The only way to do this, is to use an
SOC-FPGA (Xilinx Zync, Altera Cylone V / Arria) with ARM CPU, set up an
Linux and use the IDS-Linux-Drivers.
2. Even if you can do this stuff, you are still an FPGA-Rookie. You will
have to design a framebuffer with an complete image processing pipeline,
wich is "quiet" challenging for a Master Student.
Hence you seam to have no idea what you are doing, i´ll stronly suggest
to chose another task for your master thesis!
I would try to solve this problem with a PC and OpenCV:
http://en.wikipedia.org/wiki/OpenCV
But i guess your prof wants an FPGA.
yes you are right my professor wants a FPGA ...
Please be informed this is not my master thesis ... master project and
you are right i dont have good idea about it yet ... but the thing is
... at this moment my task is only choosing a FPGA ...
If please suggest some fpga which is compatible with this camera then i
can study them and may then i can understand the problems here you
mentioned ...
Apart from that if i dont understand the problems with the camera i cant
argue with my professor ... can you please tell me little bit more about
the problems , for example what is the problem with USB 3.0 interface
... what do you mean by i have to write a USB driver ..
I know my knowledge is very poor but i already started it and i have to
finish it in next 20 days ... i will very grateful if someone/you can
suggest me some links or documentations wwhich i can study and gather at
least some ideas that i can understand about the problems you are
talking about ..
> mentioned ...
an FPGA is not compatible as it is, with this cam, it is your job to
make it compatible!
doing 5 min on google, an found no eavluationboard with USB 3.0 host,
perhaps such ab board dont even exist yet!
I would suggest, you contact the manufacturer of the cam.
http://en.ids-imaging.com/contact.html
Describe you situation and ask, if they know a FPGA-Board, wich is
capable to control the cam, an if they think it es even possible!
If they dont know any board with USB 3.0 host, then you can tell your
prof, that you will have to make your own board.
Xilinx has USB-3.0 IP-Cores:
http://www.xilinx.com/products/intellectual-proper...
With an Xilinx Zynq-7000 (SOC-FPGA with ARM CPU) you might be able to
use the Linux-Driver from IDS to control the cam.
If you can chose another cam:
http://de.ids-imaging.com/store/produkte/kameras/g...
Gigabit ethernet is way easier to interface with common FPGA-Devboards.
You see: that is usually the last step of the process. So, if you don't
know in DETAIL what you have to do, you cannot choose hardware!
Lets try it with an analogism in the "real" world: your professor tells
you to choose the means of transportation for 4 persons from A to B
which are lets say 1000km apart. And he tells you that it has to be
comfortable. Thats all.
Now: what will you choose? A car? Going by rail? Or the bus?
Each of the solutions is ok because all the known parameters are met.
And you can assume that theres a street between A and B...
But: what if theres sea between the two points? Is there a ferry? When
the two ponits are at the coastline even going by ship is possible. But
when one person gets seasick then its not comfortable...
Or maybe its better to go by plane? Its fast, quick and mostly
comfortable. But its expensive. Ooops! A new parameter...
You will not find "the FPGA" you can interface the camera to. You will
have to add an external transceiver to the FPGA and implement or buy an
IP-Core (one like this: http://www.dgway.com/USB3-IP_A_E.html) to
connect to the camera. Of course you will have to implement some kind of
"driver" stack to talk to the camera. All in all it will be fairly
difficult to get the picture data from the camera.
Maybe you should choose a operating system running on a processor on
FPGA, but now you see, its getting closer and closer to "traditional"
computer structures. And maybe that isn't fast enough...
  • [vhdl]VHDL code[/vhdl]
