Forum: FPGA, VHDL & Verilog multiple connection
Author: sebgimi (Guest)
I want to connect 2 components in vhdl but I have some trouble to write
the code because of multiple connections in port map.
The output of the component is a real_vector(0 to 3) and is connected to
multiple outputs of an other component as below:
fast_anlog_in(0) => adc1_vinp(0), adc2_vinp(0)
fast_anlog_in(1) => adc1_vinn(0), adc1_vinp(1), adc2_vinn(0),
adc2_vinp(1)
fast_anlog_in(2) => adc3_vinp(0)
fast_anlog_in(3) => adc3_vinn(0), adc3_vinp(1)
What is the good way to proceed ?
Thank you !
You cannot connect multiple outputs unless your data type can resolve
such conflicts.
If you have to connect several outputs to one input you must use a
multiplexer to select the active output.
I also thought about a multiplexer but in my case the two outputs can be
active in the same time...
FYI: signals are real type
Thank you
sebgimi wrote:
> but in my case the two outputs can be active in the same time
And: which one is "valid" for the input? Which one must "win" the input?
If one output is 1000 and the other is 500, what is the result?
: Edited by Moderator
Sorry, maybe I was not clear enough...
I have one component with one output that I want to connect to several
outputs of an other component. In attchment you have a draw of the
system for a better understanding.
Author: Duke Scarring (Guest)
I connect one output to the next input.
Sometimes I connect one output to several inputs.
But I do never ever connect multiple outputs together (except for I2C
connections).
Duke
Author: greg (Guest)
I guess that's a typo and you actually want to connect a single output
to multiple inputs? Everything else won't make sense.
Author: Schlumpf (Guest)
The structure on the photo is not the structure typically described via
port map.
It is a component that is instantiated within another component.
So give the signal a name und "attach" the outputs from the "inner"
component to the signal
sig1 <= Out1
and then attach the outputs of the "outer" component to that signal
Output1 <= sig1;
Output2 <= sig1;
  • [vhdl]VHDL code[/vhdl]
