Forum: FPGA, VHDL & Verilog How to code a register that will be written to by 2 hosts
von Ben N. (blipton)
I'm new to verilog/digital design, so not sure how this is usually
done..
I need to write to a register from 2 sources.. in this case, a pci host
and a microcontroller
Since the clock domains are all different, I can't just have multiple
processes writing to the same register..
always @(posedge pciclk or negedge nrst)
   if pci_wr & pci_addr == 0
        cntl_reg = pci_data
always @(posedge mcclk or negedge nrst)
   if mc_wr & mc_addr == 0
        cntl_reg = mc_data
So how is this typically done?
von FPGA advisor (Guest)
think of the way how you did that in rad hardware
how can two persons access one basket ánd place an apple into it if both
occur at unpredictable points of time?
write down a strategy onto a paper describing an architecture with can
handle this
you will need an apple placer, an apple replacer, two pre baskets, two
pre basket apple receivers, two pre basket apple placers, one guy who
checks for apples in the baskets, and places them into the destination
basekt, repplacing the existing apple
imagine, that "apple" means the piece of information here
for those who are confused about that all:
IF YOU CANNOT EVEN DESCIBE A PHYSICAL ARCHITECTURE WICH HANDLES YOUR
PROBLEM, THEN FPGA DESIGN IS NOTHING FOR YOU :-)
Not sure if this changes things, but the 2 will never access the
register at the same time. Basically once the PCI is done , it hands it
over the other host, which will then have exclusive access.
Then its easy: the thing you need is called "multiplexer"...
