Forum: FPGA, VHDL & Verilog Robert and Prewitt Edge Detection
Author: Mark Jomari (imaroj)
good day sir/maam!,
is this normal that there are ranges of threshold value of roberts and
prewitt edge detection that makes the image moving(image is not stable)
in the vga monitor?
thank you,.
Provide more information!
What is your problem?
What components are involved on what platform with what development
system? What is moving how fast?
Author: MaWin (Guest)
If you repeatedly use the operator on its outcome ?
sorry for a very broad question,,,  im done doing a prewitt and robert
edge detection in an fpga,, the input is a camera and the output is vga
monitor.. its working perfectly,, im just curious,, why there are ranges
of threshold value that makes the display moving, but if set the
threshold value above that threshold, it works perfectly,. im just
curious, if this is normal>? that some value makes the image move from
left to right and from right to left??? thank you
Author: FPGA advisor (Guest)
of course this is "normal" because if the non defined levels in video
systems. For HDMI Yc ranges e.g. the threshholds have to shun the black
and upper information levels and naturally issues will occur due to the
non linear transformation from the 0..255 to 16..230 value range.
Dynamic (3D) smoothing is the key
what do you mean by "non defined levels in video systems".. im using a
14Mpxel camera, then using the alterade2-115 i can interface the camera
by the videoinput of the board,.
  • [vhdl]VHDL code[/vhdl]
