Forum: FPGA, VHDL & Verilog please help edge detection
von Mark J. (imaroj)
why this is happening?? please,. i just used 2Mpixel camera then used
the vga as the output. thank you for your response
What happens and what did you expect instead?
What way do you get from one to the other?
Read your own post as everybody here must read it: without ANY knowledge
about your problem. You will see: nobody cannot understand anything!
And: what has your problem to do with FPGAs, Asics or other programmable
logic?
If so: what platform? What hardware? What toolchain?
: Edited by Moderator
im sorry,. what i mean is,. on the left side is the sobel edge
detection, and on the right side is the grayscale input,,
,. why the output looks like that?
: Edited by User
von Bitflüsterer (Guest)
The output looks like it looks, because you applied what you applied.
Once again. Read your question and consider what a reader must know in
order to help you.
So, what do you expect and in which specific does it deviate from what
you get?
von Hans Ulli K. (Guest)
Hmmm,
you have a "shadow"
wrong double/buffering ??
or you have only one buffer for input and output.
This is wrong.
i think so,. because in my simulation in modelsim, the result of the
sobel edge detection takes 7 posedge clk before getting the magnitude,,
how can i control the delay of the output of vga,?
von FPGA advisor (Guest)
that cannot be the reason for these double image one can see in your
examples. this is either a sobel filter issue or something else.
i use pipelining in this program,, as of now, it is working correctly,,
one question,, hows the clken works?
