Forum: FPGA, VHDL & Verilog multiplication real with std_logic vector
Author: sebgimi (Guest)
Hi everyone!
I want to multiply a std_logic_vector value (14 bits) with a real
number.
But there is a problem of size of data I think. The compiler show me
these errors: "operator argument type mismatch"
Below the part of code I wrote:
data <= data * std_logic_vector(to_signed(integer(1.5*8192.0),data'length))
               when VREF_ADC_COM_value = 0.6 else
        data * std_logic_vector(to_signed(integer(1.2*8192.0),data'length))
               when VREF_ADC_COM_value = 0.75 else
        data;
How can I fix it ?
Thank you!
sebgimi wrote:
> How can I fix it ?
Is this code only for simulation?
What packages/libraries do you use (the first few lines of your HDL
code)?
Yes it's only for simulation.
The libraries I use:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
Then you cannot multiply two std_logic_vectors. Use signed or unsigned
vectors instead.
BTW: What data type is data?
data is a std_logic_vector(13 downto 0)
So, do I have to create an other signal "data unsigned" to use in the
multiplication?
Like this:
signal data          : std_logic_vector(13 downto 0);
signal data_unsigned : unsigned(13 downto 0);
data_unsigned <= data_unsigned * unsigned(integer(1.5*8192.0),data'length))...
data <= std_logic_vector(data_unsigned);
I'm a little bit lost with all these types...
Have a look there (try Google translator,its German):
http://www.lothar-miller.de/s9y/categories/16-Numeric_Std
And then remind: in the numeric_std the multiplication is only defined
for signed and unsigned vectors.
Then your calculation must look this way
 data <= std_logic_vector( signed(data) * to_signed(integer(1.5*8192.0),data'length) );
But why not definig data itself as a signed vector?
The result of a vector multiplication is twice the with of a single
vector (or the sum of the bits of both).
I would do the calculation in integer. Then you don't have to hassle
aruond with vector lengths:
 data <= std_logic_vector(to_signed(to_integer(signed(data)) * integer(1.5*8192.0), data'length));
> aruond with vector lengths: data <=
So, if I understand right, I have to declare data as a signed vector of
28 bits and write the line of calculation above ?
sebgimi wrote:
> declare data as a signed vector of 28 bits and write the line of
> calculation above ?
It you do so, this will be enough:
data <= to_signed(to_integer(data) * integer(1.5*8192.0), data'length);
  • [vhdl]VHDL code[/vhdl]
