Forum: FPGA, VHDL & Verilog I2C vs. SPI (64 slaves)
von Daniel G. (dgreenheck)
I am designing an FPGA-based project that will connect with 32-64
gyroscope sensors (all the same make & model) on a single circuit board
either using I2C or SPI.
Obviously I2C seems like the way to go here since there are so many
devices. However, there is only one pin on the gyro to change the LSB in
the I2C address, meaning that there are only 2 unique addresses
possible. This would require implementing up to 32 I2C buses on a single
FPGA (is this even possible?), as well as the 32 pull-up resistors I
would need.
I've been leaning towards SPI since I can afford the extra CS lines and
can run it all off of one bus. It also has lower power consumption and
doesn't require any pull-up resistors. I am just worried about the
capacitance being too large and slowing it down with that many devices
connected.
Am I correct in choosing SPI for this application? Are there any
disadvantages to using SPI that I am not thinking of? Or perhaps a way
to get around the address problem with I2C?
Thank you
Dan
: Edited by User
von Schreiberling (Guest)
SPI is "better" than I2C, because it is:
- fully bidirectional
- is push-pull -> faster and more robust
- a lot easyer to implement both in VHDL and Software
the main disatvantage is pin usage - you need 4 instead of 2.
So, if you can afford the pin usage, SPI is the "better" choice. 64 CS
pins are a lot of pins and a lot of Tracks on your board. You could use
shiftregisters for that.
This can go down to 5-6Pins for your whole board : CLOCK DATA  Enable
for shiftregisters, MOSI, MISO, SCK. And only 2 Blocks in your FPGA.
You also may need drivers for your signal because the fanout of your
FPGA pins may not be enough to drive 64 Targets.
Perhaps there is another possibility:
You can ask the supplier of your I2C-Device, if there are more different
slave addreses avaliable. This is sometimes the case. Every bit of
address difference saves half the busses.
von Klaus Skibowski (Guest)
maybe you could you cascaded I2C multiplexer (like TCA9548A)
should be: maybe you could use cascaded I2C multiplexer (like TCA9548A)
The implementation of an SPI Master ist extremely simple because SPI is
just connected shift registers. And with fixed SPI slaves you can use
fixed hard coded CPHA and CPOL values.
Have a look at this:
http://www.lothar-miller.de/s9y/categories/45-SPI-Master
Try Google translator, its German. This SPI is used many times and it is
very straightforward.
> I am just worried about the capacitance being too large and slowing it
> down with that many devices connected.
I would implement 8 of the simple SPI masters. Then theres no hassle
with bus loads or high capacitive load.
von René B. (reneb)
If you have enough lines and space left you should prefer SPI.
A stable and robus I2C state machine on an FPGA together with a data
handler for 64 slaves is lot's of effort and risk.
Try to use multiples SPIs of course. You may have a chance to collect
all slaves at once by slowing down and doing a quick math of course.
Let's make an rough(!!!) capacitance estimation and a rough (!!!)
frequency of operation estimation:
64 slaves on a signle line with each a I/O and line capacitance of 22pF:
64 * 22e-12 = 1,40800 × 10-9 => Lets say 2nF.
Driver output resistance of about 100Ohms.
=> CutOffFrequency is at about (1/2*Pi*R*C) 800kHz.
=> FrequencyOfOperation is at about 800kHz/10 => 80kHz.
If each participant is capable of charging/discharging a 2nF load then
you may try at 80kHz.
I would hardly give it a try at an SPI rate of 80kHz, maybe 100kHz. More
needs a much better calculation. And it just "feels" to risky.
But the same math with four SPIs and each of them having only 16
participants leads to: ~0,5nF and about 3,2Mhz => 300kHz SPI-Rate.
Finally to say: Do the math with real values and give it a lot's of
reserve and see what the results are and if you can take the
responsibility for that.
BTW: As you can see an I2C is very speed-limited by the PullUp-Resistor
and the load-capacitance. Although you can not connect 64 participants
in your application the same math (2nF, 1k PullUp, x10 reserve) will
lead to 8kHz I2C rate :-)
: Edited by User
von Michael F. (mifi)
Hello Daniel,
I could not find any information if it is OK to read out the devices
one after another or must it read out simultaneously?
Best regards,
Michael
Michael Fischer wrote:
> Hello Daniel,
> Best regards,
> Michael
They will need to be read out simultaneously.
von wtf (Guest)
WTF?
von dunno.. (Guest)
what exactly is the point in having 64 gyros on one board anyway..? 64
dimensional movements..?
furthermore.. if you want to read simultaniously, you will need a single
bus for each one..
Let me rephrase that. The sensors measurements should be done
"simultaneously" in the sense that the frequency at which they are
sampled is much much higher than their bandwidth, so they are
essentially sampled at the same time.
Thank you all for your responses! You all have confirmed the worries I
had and provided several feasible solutions which I will be looking
into.
Thank you for taking the time to answer my question, this forum is very
helpful!
> You all have ... provided several feasible
> solutions which I will be looking into.
Pls let us know what the final solution is...
von ABC (Guest)
at least one more idea:
You have 64 I2C devices, which runs simultiounously. For my
understanding you have the chance to reduce the number of pin counts,
when you use only 1 clock line for every 64 devices, and 64 data lines.
So you have 65 lines instead of 128.
If it is possible to share 2 Gyros on on I2C bus, you can furthermore
reduce some pins by using only 1 clock pin! For my opinion this results
in a comfort way using many I2C devices.
Cheers
ABC wrote:
> For my understanding you have the chance to reduce the number of pin
> counts, when you use only 1 clock line for every 64 devices
This is not possible when the unknown devices use clock stretching...
: Edited by Moderator
von ABC (Guest)
That's correct. I missed this information. Normally I2C devices are very
simple and don't use clock stretching. Which device does the TO use? I
think the TO can find out if he had to care about clock stretching.
