Forum: FPGA, VHDL & Verilog adc-fpga interface guidelines for vhdl
von jeorges F. (Company: xlue) (khal1985)
I want to interface 4 separate ADCs or (One ADC that can handle 4
different inputs in the same time) with Cyclone IV fpga. The fpga
masters the control lines of the ADCs/ADC and it also acquires the
digital data from the ADCs/ADC through parallel or serial bus(not
decided yet).
I will have to acquire data from all four Adcs/ADC simultaneously. I am
a beginner when it comes to VHDL and I have no idea on the time span of
the data acquisition.
Do you have some references about chips that i can use for this stuff?
What are the things I will have to consider in VHDL to make sure that
all 4 Adcs are controlled effectively and data is acquired without any
time lag between one another.
Replies in terms of Logic blocks in the code and example code for ADC
data acquisition will be really helpful.
Best Regards
von St. D. (st_d)
Decide on your ADC and try to realize the communication interface, which
is described within the datasheet, via VHDL. If you are a total
beginner, start with simpler stuff, for ex. design a UART module.
As you gain a bit experience with FPGA design, you will see that your
current question makes very little sense ;)
von St. D. (st_d)
opencores.org will be also a good friend to you...
von Achim S. (Guest)
There are multichannel ADCs which sample the input voltage on all
channels simultaneously (AD7606 for example). The data transfer to FPGA
happens sequentially afterwards, but the voltage on all channels ist
measured at the same point in time.
From VHDL point of view the control of the AD7606 just needs an
SPI-block. But you have to ensure, that the ADC also fullfills your
other requirements (which you did not describe), like samplerate, analog
bandwidth, accuracy, ....
von Librarian (Guest)
http://www.ti.com/lit/ug/slaa545/slaa545.pdf
Best regards,
Ok, thank you all for your replies. i take notes.
@  Achim S:
>But you have to ensure, that the ADC also fulfills your
other requirements (which you did not describe), like sample rate,
analog
bandwidth, accuracy
I need a sample rate of 100 kSPS for ecah channel minimum.analog
bandwidth ±5 V, accuracy 16 bits
Best regards
Then the AD7606 might indeed be a good solution for you. It delivers up
to 200kS/s (simultaneous on all channels), input range can be configured
to +/-5V, resolution is 16 Bit.
Some of your specifications don't get to the point (mixing bandwidth
with input range and -most probably- mixing accuracy with resolution).
But the AD7606 really looks like a good starting point. You should have
a closer look at it and see, if it really meets all your requirements.
Ok, thank all you for answers, i'll take your remarks in consideration
Best regards
