Forum: FPGA, VHDL & Verilog On live data processing with Altera FPGA Cyclone IV
Author: Enrique Perez (flote21)
Hello everybody,
I am inside of a project where I am in charge of the VHDL design using
an ALTERA FPGA Cyclone IV. This FPGA has to control a RGB sensor and
this RGB sensor provide the information of the pixel output through a
LVDS interface. In my FPGA design I implemented a module in order to
control the RGB sensor and receive the pixel output.
The value of 4 pixels are reveived in parallel with a frequency of
150MHZ. Si I had to designe a module for interfacing the FPGA with the
sensor. This module was implemented in a succesfully way because I am
able to see the values of the pixels on real time thanks to the Signal
TAP (it is like chipscope in xilinx). But in this point I need to do
some kind of data processing on real time before send this data to the
PC via Ethernet.
The data processing that I need to do consisits in adding up the RGB
infomation. I mean, every 150MHZ I receive 4 pixels in parallel. Thanks
to the known Bayer Pattern, it is possible to predict which pixels have
information of Red, Green or Blue. Then I need to make small packages of
32 pixels and adding up the values of the pixels with the same color and
send the total value to the PC.
And it is in this point where I don¨t know exactly how to do programm in
VHDL. I have nerver handle d on real time data with a FPGA and I have
never made a data processing on real time, too. For this reason I would
like to ask in this forum if someone could give me some tips or some
good documentation to read to reach my target.
Thank you very much in advance.
: Moved by Moderator
Author: Jürgen Schuhmacher (engineer)
You could take advantage of a consultant of FPGA-based image processing.
I heard, there are some in this forum. :-)
Seriously: You allready explained the task, to to:
>adding up small packages of pixels
Requires an addeder or a field of adders in case of 2D-processing and
some timing around that. Basically this will lead to a
set/reset-accumulator.
There is nothing special about this. For common image processing, there
would be things to to like:
deBayering, flat field correction, gain offset re-linearisation, pixel
binning, lense distorsion correction and all of that in the right
sequence.
Author: Enrique P (Guest)
Thanks for your advise,
But I am a little bit afraid about the timming. If I have to make the
"adding on real time, and I have to store the samples in a FIFO, in the
mean time what i am reading the FIFO and process the data read, I am
missing incoming data. Maybe I will need to implement a ring memory,
right?
Other question is, how can I measure the LVDS channels with a normal
Oscilloscope? Is it possible with the normal probes? Or I need special
ones?
thanks.
  • [vhdl]VHDL code[/vhdl]
