Forum: FPGA, VHDL & Verilog Ported linux to fpga
Author: James Yunker (Company: Naval Undersea Warfare Center) (newport_j)
Has anyone ported a version f Linux to an fpga?
Respectfully,
Newport_j
Author: Testfall (Guest)
A 8-bit µC and then:
http://dmitry.gr/index.php?r=05.Projects&proj=07.%...
The Problem is:
You will need a processor implemented on your FPGA due to the fact, that
every operating system is a programm and not a piece of
(VHDL-describable) Hardware.
Author: Sure (Guest)
Yes.
Author: experto (Guest)
this discussion brings my to the question, if there is a chance to bring
out a hardware in an FPGA wich has a kind of ready built operating
system similar to linux? i mean with real parallelized architecture and
not threads.
Author: 132 (Guest)
> not threads.
Why in the name of god should anybody to this? Of course it is possible
but seriously why?
Yes you could rewrite the whole kernel + modules + drivers + ... this
would cost literaly millions of hours. Understanding original Linux
sources and porting them to a parallelized architecture. But why do
this. Most of the programms written have a more or less sequential
natur. Most of the time you would need to emulate a sequential
environment. Only very few programms require massive parallel
processing. Even only very few of them have the ability (nature)to make
use of parallel processing. For these programms there are dedicated
solutions like CUDA where massive parallel processing can be done.
FPGAs have a special area of operation where they are useful and good.
But Linux is definetly not within this area! It is simply the wrong. You
wouldn't try to transport a 50 tons weight on a ferrari and you would
never choose a truck to win a formula 1 race. It's simply the wrong
vehicle for the purpose.
Author: 132 (Guest)
* purpose = intended purpose ... sry-.
Author: Schreiberling (Guest)
of corse. Anything you need is already avaliable. You dont even need a
very big FPGA.
You need:
- a 32bit processor linux compatible softcore (e.g. ARM)
- external RAM
- some storage media like flash  SD-Card  USB-stick
The linux runs on the softcore. You dont need to port anything since
linux for is already avaliable for several architectures - just pick a
compatible softcore.
Example : ALTERA NIOS2 :
http://www.rocketboards.org/foswiki/Documentation/...
But dont expect high speed, sofcores will run around 100-200MHz max.
If you need more performance, choose a FPGA with embedded processor.
Author: Max (Guest)
Xilinx has high-end fpgas with an integrated arm-core. You can use the
arm to run Linux (in fact some of the demoboards come preloaded with it)
and push configuration to fpga.
Dave Jones (eevblog) did a video on it about half a week ago.
Author: ChristophZ (Guest)
> not threads.
Of course you can do processing on real parallel hardware instead of
threads. The most simple solution is to start on thread per CPU Core
available. This scales from small embedded devices up to supercomputers.
Other ideas and solutions also exist, one is for example a risc-like cpu
with a extended register file. The register file itself implemented
eight times and you have assembly instructions to switch between the
different sets (and also instructions to implement a simple round robin
scheduler directly in the cpu hw). This CPU was called Transputer (in
fabrication until 1991 or so).
Some ideas of it are still alive in the microprocessors of XMOS.
As a hardware designer, in my opinion, the Propeller chip from Parallax
is also a nice thing to look at. A small microcontroller with eight or
so processing cores (used to have "multi threading" like you described)
and separately a programmable hardware based scheduler (also maintaining
access rights to the I/O pins).
But all this ideas conflict more or less with with other inventions
modern high clockrate processors use (long pipelines, large coherent
caches, branch prediction).
A completely different idea was the FPMA, field programmable math array,
by mathstar. A technologie more flexible than a GPU but less low-level
than a FPGA (The building blocks where register files, ALUs and control
blocks instead of LUTs or Shaders).
Nice idea I thought, but the company already died.
  • [vhdl]VHDL code[/vhdl]
