Forum: µC & Digital Electronics nsec-resolution time measurement with MSP430 or alternatives ?
von Juan S. (Company: JSM) (jsln)
Hello,
I am trying to measure the time between two pulses with a resolution of
<10nsecs, using a cheap microcontroller.
I know some MSP430 parts (MSP430F51x1) include the Timer D which allows
a resolution of 4ns, but I do not know of any development kit available.
Anybody has experience with this processor or knows of some other uC
that allows this kind of time measurement?
Thanks,
Juan.
von gpsdo (Guest)
You do not write about the application:
perhaps something like that?
http://www.febo.com/pipermail/time-nuts/2014-February/082820.html
thanks for the link, it seems interesting,
however I would like just to use a development kit without added
electronics, connecting PPS signals to GPIO inputs.
I want to measure time between a number of PPS pulses coming from a GPS
device as well as some computer synchronized with PTP.
Regards,
Juan.
von Uwe Bonnes (Guest)
While the STM32F334 has a timer with 217 ps resolution, it is a pity
that this resolution is only for output, not for capture, as the poster
asked.
The Infineon Cortex Parts also have sub-nanosecond timers, but I don't
know if this resolution can be used for capture. And datasheet download
still requires a NDA!
You can get about 5 ns resolution with the STM32F405 and bigger parts,
running the timer at 168/180 MHz or LPC43xx at 204 MHz.
von Georg (Guest)
> a resolution of 4ns
You need of course a high clock frequency, but this condition is
"necessary but not sufficient". Also all other elements must be fast
enough, e.g. the input to control the capture. I dont believe that this
is possible, since not all parts of such a processor are GHz fast.
Georg
von 6A66 (Guest)
Hi Juan,
as to my knowledge all uC using a high relsolution timer do so for the
OUTPUT of the timer. The TI C2000 series even goes down below 1ns but
there is no way to do a single measurement with this resolution. Using
repeated signals one could think about soltions like tuning the timer
output and comparing the signals.
Another option would be to feed a delayline with e.g. 1ns taps and to
latch the taps into a register to do the measurement.
rgds
Thanks all for your suggestions,
I am now looking into these alternatives which on paper seem to be able
to cope with high resolution capture timer (less than 10nsec):
- STM32F405 as suggested above
- MSP430F5172
http://www.ti.com/product/MSP430F5172/datasheet/specifications#SLAS6194794
Regards,
Juan.
von ChrisSo (Guest)
Hi Juan,
I have the same problem and just wanted to ask if you have already found
a suitable solution. I would appreciate an answer.
best reguards Chris
Chris,
I have had success with a MSP430F5172 in a Schmartboard:
http://www.schmartboard.com/index.asp?page=products_dev&id=641
I need to do more testing to precisely measure resolution/jitter and add
a serial port output, but my initial tests seem to work OK, you can have
a look at the code here:
https://github.com/jsln/msp430-time
regards,
Juan.
von Arc N. (arc)
von W.S. (Guest)
In this case I would suggest, to divide the problem into two separate
problems:
1. measure the raw time span by counting with the available timer of
your system
2. make a small time analog measurement from the starting edge of your
signal to be measured to the counting edge of your raw measurement
clock.
This is rather easy, if you have a small CPLD or a high speed TTL: after
a reset a open collector shortcuts a resistor+inductivity (in series) to
ground. This is a simple constant current source.. When the starting
edge comes, the open collector is released, this rises the voltage on it
and fron this node a fast diode goes to a capacitor, which is loaded by
the constant current. When the edhe of your reference clock comes, it
resets the open collector to ground again the current source. After that
you have some time to measure the voltage on the capacitor with the
builtin ADC and then zero out the capacitor to ground , now ready for
the next measurement.
This is applicable for a small amount of digits, let me say for a time
span of 20..50 ns with a useable resolution of approx. 5 bits, which
makes ca. 1 ns resolution in time.
Obviousely, it needs to be calibrated.
W.S.
von gg (Guest)
Try the LAUNCHXL-F28027 C2000 Piccolo LaunchPad from ti.
the processor contains a HRCAP module . 300ps reolution on capture.
Search "HRCAP" and youll get more info.
