Forum: FPGA, VHDL & Verilog equivalent high-Z in real?
von bob (Guest)
Hi all,
The question is in the subject, I want to know if there is an equivalent
to the high impedance state for real type?
For instance in the case of switches with real signal inputs/outputs. I
thought to write 0.0 instead of 'Z' when the switch is open but is it
right or not?
bob wrote:
> I want to know if there is an equivalent to the high impedance state for
> real type?
NAN is "Not A Number" which is a kind of "undefined state".
But you will not have the ability to drive two floats on one signal
wihtout defining your own float type with a resolution table...
von bob (Guest)
Well, I see. Maybe I can modelise a 2-1 mux with the signal I want to
drive on one channel and on the other channel "0.0" ? At least for the
behaviour of a switch
