Forum: FPGA, VHDL & Verilog ADC/DAC Spartan 3E VHDL code problem
von Irati (Guest)
Dear All,
I am currently implementing an ADC/func/DAC on the Spartan 3e Starter
Kit board. It basicly reads the analog signal, converts it into a
digital signal, apllies a multiplication and converts the result back to
an analog signal. The code is written on VHDL and compiled on ISE Design
Suite 14.6. Please find attached the main code, the ucf file and the
simulation file. I am simulating on Isim.
I have tried to simulate some parts of the implementation and it seems
to work but because of the analog input and output signals, I am having
troubles to really track the code on the implementation.
Could anybody have a look at it and tell me what I am doing wrong? As
far as I understand, the steps the ADC/func/DAC should follow are:
i)   Set the gain of the amplifier through spi_mosi.
ii)  Get the converted digital values from the ADC through spi_miso.
iii)  Apply the *2 to the digital value.
iv)  Send the digital result to the DAC through the spi_mosi.
Any help or advice will be really appreciated. Thanks a lot!
Ira
: Locked by Moderator
Why doing all steps at once? I would generate a sawtooth signal (its
just a counter) and output this signal to the DAC. Then its fairly easy
to check out this part of the design...
von Irati (Guest)
Well, as I understand it, it does one step after the other with the
risingedge of the divided clock so it is the same as having a counter,
isnt it?
von J. S. (engineer)
The treatment of the add_counter is a bit strange and it does not appear
to be complete. I also wonder about this construction:
SPI_SCK <= risingedge;
Did you respect the CLK/DATA relation correctly?
von sagar khairnar (Guest)
How  many bit ADC you are using?
von THOSHIF KHAN (Guest)
I AM GETTING OUTPUT IN XILINX ISE BUT WHEN PROGRAM IN QUARTUS-II BY THAT
TIME I AM NOT ABLE SEE OUTPUT SO I AM ATTACHING PROGRAM FILE PLZ FIND
ERROR AND SHARE AS SOON AS PASSABLE.
THANK YOU
THOSHIF KHAN wrote:
> PLZ FIND ERROR AND SHARE AS SOON AS PASSABLE.
Pls start a new thread for an new problem.
Pls describe the problem.
Pls attach .VHD od .VHDL files, not .TXT files!
Pls don't SHOUT.
> PLZ FIND ERROR
Whats the problem with it? What error do you get? What do you expect to
get and what do you get instead?
What do you pay for getting your work done?
This topic is locked and can not be replied to.
