Forum: FPGA, VHDL & Verilog ABEL to Verilog conversion
von Sutton Mehaffey (Guest)
I've used Abel for many years on all kinds of projects.  The newer
Xilinx IDEs no longer support Abel.  I still use the last version (10.5)
that has the Abel compiler.  Obviously changing languages requires some
type of learning curve.  But, I am thinking that I need to set aside
some time to learn Verilog since that seems to be the language of choice
these days in CPLD design.
Most of my projects use a CPLD as an address decode chip.  I was looking
for different schemes for a simple Abel address decode conversion to
Verilog.
A7..A0 pin 1,2,5,6,7,8,9,10;
ABUS = [A7..A0];
D0 pin 60;
WR pin 22;
RESET_BUTTON_N pin 122;
DISPLAY_POWER_P pin 121 istype 'reg_D';
DISPLAY_POWER_P.clk = !WR & (ABUS == ^h33);
DISPLAY_POWER_P := D0;
DISPLAY_POWER_P.ar = !RESET_BUTTON_N;
So, basically, this is a power line for a Display using a 'D' flip flop
as a latch.  If ABUS = 0x33, WR is low, and D0 is high, the display
turns on.  D0=0 turns the display off.  A reset button clears out the
latch.
What is the correlating code in verilog to do the same thing?  I have 50
or so exact configurations in my Abel code to turn on/off different
things, using this exact same code scheme.  So, is this an easy
conversion?
Thanks.
Sutton
von bko (Guest)
In your case it could help to read the XST-User Guide in the
Xilinx Software Manuals:
 -> Chapter 2: XST HDL Coding Techniques <-
 Xilinx has there a lot of hardware examples for VHDL/verilog.
here the verilog for a D-type rising clock edge flipflop:
>Flip-Flop With Positive-Edge Clock Verilog Coding Example
>// Flip-Flop with Positive-Edge Clock
>module v_registers_1 (C, D, Q);
>         input C, D;
>         output Q;
>  reg Q;
>always @(posedge C)
>   begin
>     Q <= D;
>   end
>endmodule
http://www.xilinx.com/itp/xilinx10/books/docs/xst/xst.pdf
von saravana bavananthan (Guest)
Please Provide Verilog code for this
von Klakx (Guest)
wow, cant believe that somebody was still willing to write cplds with
ABEL.
I do not often write verilog, but here i make an exception. so this
piece is just from scratch. test yourself and have fun!
imho, learn verilog or vhdl, it is worth it!
module whatever (
a,
d,
WR,
clk    , // Clock Input
reset , // Reset input
out         // Q output
//-----------Input Ports---------------
input [4:0] a;
input [7:0] d;
input clk, reset,nWR;
//-----------Output Ports---------------
output out;
//------------Internal Variables--------
reg q;
wire N_SIG;
//-------------Code Starts Here---------
assign N_SIG = WR& A3& A2& ~A1&~A0& D7& D6&~D5&~D4
always @ ( posedge clk or negedge reset)
if (~reset) begin
q <= 1'b0;
end  else begin
q <= N_FF& N_SIG& D3& ~D2& ~D1 & ~D0
    | ~N_FF& N_SIG& D3&~D2&~D1& D0;
30
end
31
assign out = q;
32
endmodule //End Of Module whatever
von Athos (Guest)
Hello to anybody out there listening-in accross the universe lolol. I
have a couple of ABEL source and jed files that are compiled for the
xc9500xl series of cpld. Can someone tell me if it is still possible to
either compile for the xc9500 series (5v version chips), or if possible
how to modify the jed files to fool jtag programming into believing the
xl versions are present ?
von Duke Scarring (Guest)
Take a new topic for a new question!
Athos wrote:
> I
Xilinx ISE before version 11.1 support Abel:
https://www.xilinx.com/support/answers/32354.html
Download ISE 10.1 and convert your Abel files to VHDL.
regards,
Duke
von krishna uppunda (Guest)
Please provide verilog code for this
