Forum: FPGA, VHDL & Verilog delay not wanted vhdl
Author: angelo (Guest)
Hi every one,
I'm writing a code for a dac in vhdl and I have some troubles during
simulation: a delay appears on two signals what is not what I want...
My code:
library IEEE;
use IEEE.std_logic_1164.all;
use ieee.numeric_std.all;
entity dac is
  generic (data_width : integer;
     SDI_width  : integer;
     REF        : real);
  port(  SDI   : in  std_logic_vector (SDI_width - 1 downto 0);
    SDO   : out std_logic_vector(SDI_width - 1 downto 0);
    SCK   : in  std_logic;
    CLR   : in  std_logic;  -- low level active
    CS_LD : in  std_logic;   -- '0': CS / '1': LD
    LDAC  : in  std_logic;  -- low level active
    Vout  : out real
end dac;
architecture archi of dac is
signal data      : std_logic_vector(11 downto 0);
signal data_real : real;
begin
  data <= SDI(15) & SDI(14) & SDI(13) & SDI(12) & SDI(11) & SDI(10) &
    SDI(9) & SDI(8) & SDI(7) & SDI(6) & SDI(5) & SDI(4);
  P1: process(SCK)
  begin
    data_real <= (real(to_integer(signed(data))));
    if (CLR = '0' or CS_LD = '0') then
      Vout <= 0.0;
    elsif (SCK'event and SCK = '1') then
      Vout <= data_real/(2.0**data_width) * REF;
    end if;
  end process;
end archi;
In simulation this is a delay of 5 ns on the "data_real" signal and 15
ns on the signal "Vout".
Do you know what is wrong in my code and how to fix it please ?
Your problem ist the wrong sensitivity list...
Try this and think about it:
  P1: process(SCK,data,CLR,CS_LD) ...
THis line can be shortened:
Try it this way:
data <= SDI(15 downto 4);
: Edited by Moderator
Thank you for your answer, with all your advices the issue is
fixed...partially.
No more delay on data_real signal, but still on Vout signal. Now it's a
5 ns delay instead 15 ns.
Did I miss something ?
Never mind, I'm just silly!
It's all good! Cheers
angelo wrote:
> It's all good!
To all the others: there must be a "delay" due to the clock, obviously.
  • [vhdl]VHDL code[/vhdl]
