Forum: ARM programming with GCC/GNU tools Packing structures on bit boundaries
Author: Charles Zi (geodesic)
I have a an issue with gcc and I am looking for help.
I am trying to use a library that was designed for a different
environment on a RAM constrained cortex-M0 processor. The library itself
makes extensive use of structures like the following (details removed to
express the problem succinctly):
struct {
   struct {
      int chan1;
      int chan2;
   } dma;
   int state;
} X;
By default, this takes up 12 bytes. But the range of possible values for
these fields are very small. I would like to change it to the following:
struct __attribute__(( packed )) {
      uint8_t chan1:2;
      uint8_t chan2:2;
   } dma;
   uint8_t  :1;
   uint8_t  state:3;
} X;
This structure should only take 1 byte. But it seems gcc is always
padding out the dma structure to a full byte, and then placing the state
field in a second byte. So my structure winds up with size 2. I have
read everything on the net and have not yet found anything which would
allow me to tell gcc not to pad the dma structure, or to align it on a
nibble boundary.
I am stuck with this structure. To change it would require changing it
in hundreds of places of C code, and worse, redoing it every single time
there was a library code update.
This is doubling my RAM usage. If I could find a way to make gcc behave,
then we could squeeze into a smaller part.
Does anyone have any idea on a way to make the gcc compiler be more
accommodating to my constraints?
Thank you for any assistance.
Author: Rolf Magnus (Guest)
Yes, because it's a separate type. The dma struct is one bit field that
must have a size that is a multiple of one byte. That doesn't change
just because it is embedded into another structure with bitfield
elements.
> I have read everything on the net and have not yet found anything which
> would allow me to tell gcc not to pad the dma structure, or to align it
> on a nibble boundary.
I don't think there a way to put bits of multiple bit fields together
into one byte.
Then better start now ;-)
> and worse, redoing it every single time there was a library code update.
Why?
