Forum: FPGA, VHDL & Verilog using generate with clk
Author: stas (Guest)
I'm using generate to create 32 dff's to work as a shift register,
that part works great.
The problem is, that i want to input data only on rising edge of the
clock,
but the actual insert takes place half clk after that.
Do i need to change the generate itself?
thx !
this is the component that activates the generate:
begin
  dffx: for i in 1 to 31 generate
  lsb: if i=1 generate
    dff1: dff24 port map
    (clk,rst,data_in,fir_array((24*i-1) downto (i-1)*24));
  end generate lsb;
   msb: if (i>1)and(i<=31) generate
    dffs: dff24 port map
    (clk,rst,fir_array((24*(i-1)-1) downto (i-2)*24),fir_array((24*i-1) downto (i-1)*24));
  end generate msb;
    end process;
  end generate dffx;
this is the component that the generate use:
architecture beh of dff24 is
  begin
    process (clk, rst)
      begin
        if(rst = '0') then
          q <= "000000000000000000000000" ;
        else if (rising_edge(clk)) then
           q <= d;
         end if;
        end if;
      end process;
  end beh;
: Edited by Moderator
Try that for posting VHDL code:
[vhdl]
  VHDL code
[/vhdl]
> clock, but the actual insert takes place half clk after that.
Which insert to what?
You are using 24*32 dffs for a amazing complex looking shift register...
What do you want to get with that? What is your actual task to do?
begin
  end generate lsb;
  end generate msb;
    end process;
  end generate dffx;
  begin
    process (clk, rst)
      begin
        if(rst = '0') then
           q <= d;
         end if;
        end if;
      end process;
  end beh;
the project itself is to build fir filter, this part of the project
should only store every sample (every sample size is 24 bits and there
are 32 samples), every rising edge i wish to insert the new sample to
the first flipflop and move the last sample to the next.
The result would be 32 samples in 32 flipflops as the last one in is in
the number 1 flip flop.
Author: Achim S. (Guest)
So you want to store 32 samples in 32 registers, where each registers
contains 24 Flipflops, correct?
How do you come to this conclusion? Observed by oscilloscope? Observed
by behavioral simulation or timing simulation?
Everthing in the shown code works on the rising clk edge. So in
behavioral simulation you should see the FFs are switching triggered by
But if you run timing simulation or monitor the FPGAs outputs with an
osci, you will see the switching after some delay (cause the switching
takes some time, the routing from the FF to the output causes some
delay, ...). This delay might look like the switching happens at the
falling clk edge.
  • [vhdl]VHDL code[/vhdl]
