Forum: FPGA, VHDL & Verilog divide by 3 in vhdl
von lelo (Guest)
hi
i want to know how to divide by 3 in vhdl
von Frank (Guest)
Divide what exactly?
Time? A clock? An integer? signed/unsigned? Some wierd float? Some
standard float? Divide bread? Designs in functions?
I think you got the point.
von Thomas R. (Company: abaxor engineering) (abaxor)
lelo wrote:
> hi
I suppose you will do that using integer numbers. A divide by three is
nothing more than a multiplication by 0.33333. Therefore you increase
0.33333 by 2**n and multiply your operand by this factor. From your
product you have to use the the digits product'high downto n.
Tom
Thomas Reinemann wrote:
> Therefore you increase 0.33333 by 2**n and multiply your operand by
> this factor. From your product you have to use the the digits
In other words for a 16 bit integer:
     result <= (value*(2**16/3))/2**16;
von Rolf S. (audiorolf)
I once found this cyclic definition:
x/4 + x/16 + x/64 + ...
= 0,333333333 x X
von Detlef _. (detlef_a)
Or use this from
http://graphics.stanford.edu/~seander/bithacks.html#ModulusDivisionEasy
Compute modulus division by (1 << s) - 1 without a division operator
unsigned int n;                      // numerator
const unsigned int s;                // s > 0
const unsigned int d = (1 << s) - 1; // so d is either 1, 3, 7, 15, 31, ...).
unsigned int m;                      // n % d goes here.
for (m = n; n > d; n = m)
  for (m = 0; n; n >>= s)
    m += n & d;
// Now m is a value from 0 to d, but since with modulus division
// we want m to be 0 when it is d.
m = m == d ? 0 : m;
This method of modulus division by an integer that is one less than a
power of 2 takes at most 5 + (4 + 5 * ceil(N / s)) * ceil(lg(N / s))
operations, where N is the number of bits in the numerator. In other
words, it takes at most O(N * lg(N)) time.
: Edited by Moderator
Hopefulley lelo (Guest) doesn't try to do this in real hardware. The
variable end of the first loop will not even work in VHDL...
No, not in this form. I quoted a C-program, you can transfer the algo to
VHDL, for ex. with a state machine.
Is there anything you cant do with VHDL? I'm not an expert in VHDL, but
the answer must be 'No'.
Cheers
Detlef
: Edited by User
von ChristophZ (Guest)
The question is not, can you do it or not. The question is the cost.
When you write software, your costs are: code size, requried memory and
execution time.
When you describe hardware, your costs are: required logic elements,
power consumption and latency.
A solution that is cheap in software could be expensive in hardware and
vice versa.
> I'm not an expert in VHDL, but the answer must be 'No'.
Why must the answer be 'No'?
Ok, messed up this one. lelo wanted a division by 3, my post was about
modulus division :-(
Here is the right answer. It is adapted from
http://www.hackersdelight.org/divcMore.pdf
and comes with only shifts and addition and without variable count loops
That comes in handy, you VHDL gurus, right? (but still its C language
though)
Cheers
Detlef
PS:
Because VHDL is turing-complet, hopefully.
unsigned int n=33333;                      // numerator
unsigned q, r;
q = (n >> 2) + (n >> 4); // q = n*0.0101 (approx).
q = q + (q >> 4); // q = n*0.01010101.
q = q + (q >> 8);
q = q + (q >> 16);
//printf("%d \n",q ); // Returning q + r/3.
//r = n - q*3; // 0 <= r <= 15.
r = n-(q<<1)-q; // 0 <= r <= 15.
//r=q + ((11*r) >> 5);
r=q + (((r<<3)+(r<<1)+r) >> 5);
     printf("%d \n",r); // Returning q + r/3.
// return q + (5*(r + 1) >> 4); // Alternative 1.
// return q + ((r + 5 + (r << 2)) >> 4);// Alternative 2.
return;
: Edited by User
von qnd (Guest)
you#re mixing up things. If you can write it in VHDL it does not mean
you can built a efficent FPGA design from it.
Of course you can write an SOFT-CPU in VHDL, implement an FPGA with it
and programm the core in C - but thats rather inefficient.
Best regards,
Detlef _a wrote:
> PS:
Of course you can do anything in VHDL. You also can drive in a screw
with a hammer. Its a fairly inefficient way, not always leading to the
best result, but of course you can...
To get good results (=small and fast) you must use algorithms that can
be implemented on Hardware in an efficient way (try google translator,
its german):
http://www.lothar-miller.de/s9y/archives/67-Vektor-nach-BCD-kombinatorisch.html
http://www.lothar-miller.de/s9y/archives/34-Vektor-nach-BCD.html
http://www.lothar-miller.de/s9y/archives/78-Bubblesort.html
http://www.lothar-miller.de/s9y/archives/89-BCD-nach-Binaer-wandeln.html
von lelo (Guest)
> In other words for a 16 bit integer:     result <=
it can be implemented also
