Forum: FPGA, VHDL & Verilog Basic ALU in VHDL
von VHDL_Help (Guest)
Hi, first time posting! I'm trying to create a basic ALU. However, when
I try to synthesize, I get the following errors:
ERROR:Xst:2588 - Port <a> of top entity <ALU> is not constrainted.
ERROR:Xst:2588 - Port <b> of top entity <ALU> is not constrainted.
ERROR:Xst:2588 - Port <op> of top entity <ALU> is not constrainted.
ERROR:Xst:2588 - Port <y> of top entity <ALU> is not constrainted.
Any help please?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity ALU is
    Port ( a : in  STD_LOGIC_VECTOR;
           b : in  STD_LOGIC_VECTOR;
           c_in : in  STD_LOGIC;
           op : in  STD_LOGIC_VECTOR;
           y : out  STD_LOGIC_VECTOR;
           c_out : out  STD_LOGIC;
           v : out  STD_LOGIC;
           z : out  STD_LOGIC;
           s : out  STD_LOGIC );
end ALU;
architecture Behavioral of ALU is
  signal signal_a : STD_LOGIC_VECTOR (7 downto 0);
  signal signal_b : STD_LOGIC_VECTOR (7 downto 0);
  signal signal_c_in :STD_LOGIC;
  signal signal_output : STD_LOGIC_VECTOR (7 downto 0);
  signal signal_c_out : STD_LOGIC;
  signal unsigned_a, unsigned_b : unsigned (7 downto 0);
  signal unsigned_c_in : unsigned (0 downto 0);
  signal unsigned_output : unsigned (8 downto 0);
  signal not_a : STD_LOGIC_VECTOR (7 downto 0);
  signal a_and_b : STD_LOGIC_VECTOR (7 downto 0);
30
  signal a_or_b : STD_LOGIC_VECTOR (7 downto 0);
31
  signal a_xor_b : STD_LOGIC_VECTOR (7 downto 0);
32
33
  signal signal_y : STD_LOGIC_VECTOR (7 downto 0);
34
35
begin
36
  signal_a <= NOT(a) when op = "0110"
37
          else a;
38
39
  signal_b <= NOT(b) when op = "1111"
40
          else "11111111" when op = "1110"
41
          else "00000000" when op = "0111" OR op = "0001"
42
          else b;
43
44
  signal_c_in <= '1' when op = "1111" OR op = "0001" OR op = "0110"
45
            else '0' when op = "1000"
46
            else c_in;
47
48
  not_a <= NOT(a);
49
50
  a_or_b <= a OR b;
51
52
  a_and_b <= a AND b;
53
54
  a_xor_b <= a XOR b;
55
56
  signal_y <= signal_output when op = "0000" else -- ADD
57
          signal_output when op = "1111" else -- SUB
58
          signal_output when op = "0110" else -- NEG
59
          signal_output when op = "0001" else -- INC
60
          signal_output when op = "1110" else -- DEC
61
62
          not_a when op = "0101" else
63
          a_or_b when op = "0111" else
64
          a_and_b when op = "0110" else
65
          a_xor_b when op = "1000" else
66
67
68
69
  unsigned_a <= unsigned(signal_a);
70
  unsigned_b <= unsigned(signal_b);
71
  unsigned_c_in(0) <= signal_c_in;
72
73
74
  unsigned_output <= ("0" & unsigned_a) + unsigned_b + unsigned_c_in;
75
  signal_output <= std_logic_vector(unsigned_output(7 downto 0));
76
  signal_c_out <= unsigned_output(8);
77
78
79
  y <= signal_y;
80
81
82
  v <=  ((signal_a(7) AND signal_b(7) AND NOT signal_output(7))
83
      OR (NOT signal_a(7)AND NOT signal_b(7) AND signal_output(7)))
84
      when op = "0000" OR op = "1111" OR op = "0110" OR op = "0001" OR op = "1110"
85
      else '0';
86
87
  z <=   '1' when signal_y = "00000000"
88
      else '0';
89
90
  s <=   signal_y(7);
91
92
93
  c_out <= signal_c_out when op = "0000" OR op = "1111" OR op = "0110" OR op = "0001" OR op = "1110"
94
        else '0';
95
96
end Behavioral;
von Bitflüsterer (Guest)
You forgot to declare the width of the vectors.
BTW: c_out seems to be a vector too.
