Forum: FPGA, VHDL & Verilog syncronize asynchrone input
von tester (Guest)
I am trying to synchronize an asynchrone input, to make my code work,
but it does still not not.. so i was wondering if the way i
synchronized, and debounched my signal might be incorrect.
This is how i am doing it
Process(clk)
begin
if rising_edge(CLK) then
  if switch = "0000" then
    data_out <= "0000";
  else
    data_out <= switch;
  end if;
end if;
end process;
process( Clk )
variable oldbtn:std_logic_vector(3 downto 0):="0000";
variable counter: integer range 0 to 49999999;
begin
  if rising_edge(clk) then
    if (data_out XOR oldbtn) /= "0000" then
      counter:= 0;
      oldbtn:=switch;
    else
      counter:=counter + 1;
      if (data_out XOR oldbtn) = "0000"  and counter = 49999999/4999999 then
        button <= oldbtn;
      end if;
    end if;
  end if;
end process;
First process is for syncronizing the signal with the clock, and the
other one is the debounching.
Are they incorrectly made or aren't they incorrectly made?
How did you find that out? What do you expect? And what happens?
Pls attach the whole vhdl-file (with *.vhd or *.vhdl extension), so that
the libraries and the port definiton also can be seen...
This is unnecessary because at this position data_out and oldbtn MUST be
equal:
Think about that...
A switch bounces in the milliseconds range. You are syncing way, way
faster (in the sub microseconds range). First step is to implement a
prescaler, so that you are in the correct time division...
They are much too complicated. The first process can be written as a
concurrent description without ANY change in behaviour:
    data_out <= switch when rising_edge(clk);
Why digging around with code like this
when VHDL is able to handle it much better readable this way:
    if (data_out /= oldbtn) then
BTW:
data_out is a fairly bad name for a sync'ed switch...
Debouncing is only the first step. Next will consequently be a
edge-detection. Have a look at this (try google translator, its German):
http://www.lothar-miller.de/s9y/categories/5-Entprellung
