Forum: FPGA, VHDL & Verilog Cache memory
von Mionxsq L. (cmione15)
How can i write a Cache Memory project in vhdl?? The cache is copy back
2-way... i'm trying to make a behavior description... but it's not
working.
Mionxsq Lopbc wrote:
> but it's not working.
How did you find that out? What do you expect and what do you get?
Just a little hint: VHDL is not C!!!
(I cannot make enough exclamation marks!!)
What you did is a kind of controller that may be working if it is
executed sequentially on a CPU. But it will never work as you expect on
hardware with VHDL. Read my comments...
         if (Valid='1') then
            -- forget about functions the first half year of your VHDL career.
            -- if you don't want to write the mux inline, then have a look for "components" and "component instantiation"
            DataProc<=mux4x1(Cache_OUT(15 downto 0),Cache_OUT(31 downto 16), Cache_OUT(47 downto 32),Cache_OUT(63 downto 48),Palavra);
         else   -- to come here Valid must be '0'
             Valid <= validade(V,TAG1,TAG2); --
             if (Valid='1') then -- the following code will NEVER be  "reached",
                                 -- because a SIGNAL in VHDL behaves not the way you want.
                                 -- Here /Valid/ is '0', because the "new" value of /Valid/
                                 -- is updated at the end of the process.
: Edited by Moderator
I'm trying to do it in a structural description. But I don't know how to
connect them to make it works.
Pls. attach vhdl files. I cannot open rar files on my tablet...
These ones
