Forum: FPGA, VHDL & Verilog Problems with getting into state.
von State problems (Guest)
I have a problem with timing in my program.
I have this codepiece
process(CLK)
variable prescaler: integer range 0 to 50000000;
Variable control: std_logic_vector(1 downto 0 ):= "00";
variable pointer: integer range 0 to 11:=0;
variable test: std_logic:='0';
variable error: std_logic:='0';
begin
if rising_edge (clk) then
  if control = "00" and error = '0' then
    winLEd <= "00";
      if(prescaler < 49999999/1) then
        prescaler := prescaler + 1;
      else
        prescaler := 0;
        top_pointer := top_pointer + 1;  -- Top pointer increment
        control := "11";  --- trigger event to get to new state
      end if;
  end if;
  if control = "11"  and error = '0' then
    winLEd <= "11";
    Led <= LISTEN(pointer-1);
      if pointer > (top_pointer) then   -- If pointer is higher than toppointer, it means the sequence has to be incrementet.
        LED <= "000000";
        control := "00";
        pointer := 0;
        test := '0';
        error:= '0';
      end if;
30
31
      if switch = LISTEN(pointer-1) and pointer<= top_pointer then -- Checks if the switch match the sequence.
32
33
        pointer:= pointer +1;
34
      end if;
35
36
      if switch /= LISTEN(pointer-1) and switch /= "0000" then  -- if it doesn not match, error will be set high => trigger an new state.
37
        LED(4) <= '1';
38
        error:= '1';
39
      end if;
40
      if switch = "0000" then
41
        LED(4) <= '0';
42
        error:= '0';
43
        control := "11";
44
      end if;
45
  end if;
46
   if error = '1'  and control = "10" then  -- stays here infinetly until board is reset.
47
    Led(4) <= '1';
48
    winLED <=  "10";
49
  end if;
50
end if;
51
end process;
I've commented the code to explain how it works.
LIsten is a array which contains different sequences.  The idea is that
the user have to activate the switch so they match the sequence from the
array.
My problems is that when i activate the switch for the first sequence, I
automatically end in the error state,
I think it is because the clock. it is 50 mhz, and therefore the next
sequence check appear while the switch is down from the first check.
Is there a way i can resolve this problem.
i tried adding a delay but that doesn't help so i am quite lost here..
