Forum: ARM programming with GCC/GNU tools [Solved] STM32F0 Discovery Board: Connect faild, check config and cable connection
von Markus J. (markus_j31)
Hi
I bougth the Stm32F0 Discovery to get into microcontrollers. I have only
knowlegth about c# and java programming.
I followed this tutorial (video
http://www.youtube.com/watch?v=nP6TR6NAZTQ)
Downlaoding coocox ide and CoFlash
installing gcc-arm-none-eabi-4_8-2014q1-20140314-win32.exe (md5)
and the usb driver http://www.st.com/web/en/catalog/tools/PF258167
I can build the programm but I can not load it on the microcontroller. I
get always this error:
C:\CooCox\CoIDE>"C:/CooCox/CoIDE/bin\coflash.exe" program STM32F051R8
"C:/CooCox/CoIDE/workspace/blinkingLEDs/blinkingLEDs/Debug/bin/blinkingL
EDs.elf"  --adapter-name=ST-Link --port=SWD --adapter-clk=1000000
--erase=affected --reset=SYSRESETREQ
--driver="C:/CooCox/CoIDE/flash/STM32F05xx_64.elf"
Error: Connect failed, check config and cable connection
Program Download Failed !
I have no cloue what to change. Can anyone give me a hint?
Do I Have to know anything else about the st Driver?
Thanks in advance
: Edited by User
von Uwe B. (derexponent)
are both jumpers "CN2" for the ST-Link connected ?
There are three jumper connections in place. One for the JP2 and two for
St-Link. I did not change anything since I got this board from the
manufacturer.
manufacturer.
ok, connect the board with usb and check your device manager
in "usb controller" you must have an entry like "STLink dongle"
(see picture)
if this is ok, donwload the "ST-Link Utility" from ST
and try to connect with this tool and readout the Device Information
perhaps you have selected the wrong Device
Thank you
That solved my problem.
von Basil Mathew Tharian (Guest)
That solved my problem too . Excellent solution .
von shailesh bakshi (Guest)
HI,
  I am new to stm I am using MB1034B BOARD this error "Connect faild,
check config and cable connection" I had tried all possible solution but
its still not working pls somebody help
