Forum: FPGA, VHDL & Verilog Mutiple source drivers - How to resolve it??
von John M. (215)
I have this process
state_fail_win <= test;
process(clk,anode,counter_1,counter_10, state_fail_win,anode,counter_1r,counter_10r)
variable prescaler: integer range 0 to 49999999 := 0;
begin
if rising_edge(clk) then
    if(prescaler < 49999999/200) then
    prescaler := prescaler + 1;
    else
      prescaler := 0;
      anode <= anode + '1';
    end if;
end if;
if state_fail_win = '1' then
  if (counter_1 < 9) then
    counter_1 <= counter_1 + 1;
  else
    counter_1 <= 0;
      if (counter_10 < 9) then
        counter_10 <= counter_10 + 1;
      else
        counter_10 <= 0;
        counter_1 <= 0;
      end if;
  end if;
end if;
state_fail_win <= '0';
  if state_fail_win = '0' then
    case anode is
30
      when "00" => SEG <= counter_1r;
31
      when "01" => SEG <= counter_10r;
32
      when "10" => SEG <= d;
33
      when "11" => SEG <= r;
34
      when others => SEG <= "00000000";
35
    end case;
36
  end if;
37
end process;
I don't quite see how i get this error message..
Multi-source in Unit <segment> on signal <test>; this signal is
connected to multiple drivers.
But how can i Resolve it??
: Edited by User
von Duke Scarring (Guest)
> begin
>     else
>       prescaler := 0;
>     end if;
Uhh.
1. You mix up sequential (clk) and combinatorical (without clk) logic in
the same process. That's very advanced and usally confusing for
beginners.
2. At least the signal state_fail_win is driven on diffrent places:
Outside the process and inside the process. That's construct cannot map
to hardware.
Remember this: Drive a signal only at one point and read it wherever
you need it. A process is like a chip in your circuit with inputs and
outputs.
Duke
von FPGA-advisor (Guest)
you should learn to describe any of the signals in a design only in one
process rather than accesing it from various places.
