Forum: FPGA, VHDL & Verilog A VHDL Counter
Author: Resha Lopolo (Company: Resige) (tahmod)
I want to understand this code. Can anyone tell help me, how does it
work?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity leds2_8 is
GENERIC (n:positive := 2**22);
    Port ( clkin : in  STD_LOGIC;
           clkout : out  STD_LOGIC;
           leds : out  STD_LOGIC_VECTOR (7 downto 0));
end leds2_8;
architecture Behavioral of leds2_8 is
begin
PROCESS (clkin)
VARIABLE count: INTEGER RANGE 0 to n;
variable counter : integer range 0 to 255;
BEGIN
IF(clkin'EVENT AND clkin='1') THEN
count :=count + 1;
IF(count=n/2) THEN
clkout <='1';
ELSIF (count=n) THEN
clkout <='0';
count :=0;
counter :=counter+1;
leds <=conv_std_logic_vector(counter,8);
END IF;
END IF;
END PROCESS;
end  Behavioral;
: Edited by Moderator
This code is ugly and bad formatted.
But have a look at my comments:
library IEEE;
--use ieee.std_logic_arith.all;     -- it is a stupid idea to include both arithmetic libraries!
entity leds2_8 is
  GENERIC (n:positive := 2**22);    -- define n as a very big number
    Port ( clkin : in  STD_LOGIC;   -- clkin i the oscillator input
           clkout : out  STD_LOGIC; -- read my comments to this signal down a few lines
           leds : out  STD_LOGIC_VECTOR (7 downto 0)); -- the led pins
end leds2_8;
begin
  PROCESS (clkin)      -- this process is sensitive to the clkin signal
  VARIABLE count: INTEGER RANGE 0 to n := 0;      -- why the heck does everybody use variables nowadays?
  variable counter : integer range 0 to 255 := 0; -- at least the variables MUST be initialized!
                                                  -- otherwise the simulation will not work!
  BEGIN
    IF(clkin'EVENT AND clkin='1') THEN  -- you could use the rising_edge() insted
      count :=count + 1;                -- count up the prescaler every clock
      IF(count=n/2) THEN                -- here comes a way to get fired immediately: if you present me a clock
        clkout <='1';                   -- generated this way you will work somewhere else next day!
                                        -- clocks are generated with clock managers on a FPGA!
      ELSIF (count=n) THEN              -- ok, lets go on. here the prescaler reaches its end value
        clkout <='0';
        count :=0;                      -- reset the prescaler-counter
        counter :=counter+1;            -- and increment the led-counter
        leds <=conv_std_logic_vector(counter,8); -- transfer the led counter to the leds
      END IF;
    END IF;
  END PROCESS;
end  Behavioral;
  • [vhdl]VHDL code[/vhdl]
