Forum: FPGA, VHDL & Verilog delay for syntezing on FPGA?
Author: John Mayer (215)
I have this problem with my VHDL code.
if pointer <= (top_pointer) and test = '0' then
       LED <= LISTEN(pointer);
       pointer := pointer + 1;
end if;
The Idea with this piece of code is that as i've tried to state is as
long pointer is less than top pointer, LED has to display what inside
the array listen and then increment the pointer.
the problem is that it isn't showing what the array contain.
My theory I am missing a prescaler, so i tried adding one,
  if(prescaler < 49999999/1) then
    prescaler := prescaler + 1;
  else
    prescaler := 0;
  end if;
end if;
but still same result..What am I doing wrong here??
You do not attach the questionable VHDL code. So no one is able to see
the definition of the types...
Why do you open a new thread for an old question?
Did you read and try to understand my recent answers?
Is there any clock in your design?
My code is attached in my old thread.
Yes there  is a clock attached in my design??
It isn't attached, you only added a link to some external site.
> my old thread.
For all the others:
http://embdev.net/topic/332350
It is, but up to now I did what I said: not reading an external link to
your code.
What does it show instead? And how did you find that out? Did you
simulate your design? What do you exptect to happen?
BTW:
You are playing a high league with this here:
shared variable top_pointer: integer range 0 to 4 := 0;
I rarely need a shared variable. And if so it is only for simulation.
Can your synthesizer handle shared variables?
yes... it is cappable of handling it.
: Edited by User
  • [vhdl]VHDL code[/vhdl]
