Forum: FPGA, VHDL & Verilog Why is this incorrect??
von John M. (215)
I don't get why this is incorrect???
i am trying to make hierachical design, but i am getting som weird
errors.
this is my code.
entity top is
    Port ( CLock : in  STD_LOGIC;
           LED : out STD_LOGIC_vector(3 downto 0);
           Switch : in  STD_LOGIC);
end top;
architecture Behavioral of top is
Signal numBER: std_logic_vector (1 downto 0);
component randomnumber
port (
  clk : in std_logic;
  gameon: in std_logic;
  bitteD: out std_logic_vector (1 downto 0)
end component;
component randtosequence
Port (
  LED1 : out  STD_LOGIC_VECTOR (3 downto 0);
  randbit : in  STD_LOGIC_VECTOR (1 downto 0)
end component;
begin
randomnumber1 : randomnumber port map(clk => Clock, gameon => Switch, bitted => number);
rantosequence1: randtosequence port map(randbit <= number);
LED <= LED1;
end Behavioral;
I am getting these error which i don't understand.
ERROR:HDLParsers:3312 - "C:/.Xilinx/randomnumber/top.vhd" Line 56.
Undefined symbol 'randbit'.
ERROR:HDLParsers:1209 - "C:/.Xilinx/randomnumber/top.vhd" Line 56.
randbit: Undefined symbol (last report in this block)
ERROR:HDLParsers:3324 - "C:/.Xilinx/randomnumber/top.vhd" Line 56. IN
mode Formal randbit of randtosequence with no default value must be
associated with an actual value.
ERROR:HDLParsers:3312 - "C:/.Xilinx/randomnumber/top.vhd" Line 57.
Undefined symbol 'LED1'.
ERROR:HDLParsers:1209 - "C:/.Xilinx/randomnumber/top.vhd" Line 57. LED1:
I don't understand why they are undefined, haven't i defined them??
: Edited by Moderator
von qnd (Guest)
')' is misplaced.
Additionally in VHDL '=>' is much different from '<='...
von John M. (215)
Could you specifiy where the missing ) is???
and what do mean by much different..
Isnt a => B , saying that B has the value of a
and a<= B says that a has the value of B
or am I wrong?
Of course, but to give you a little bit of a learning effect you will
have to find this yourself. Two little hints:
1. It is somewhere in the lines 56 and 57.
2. How many ports has randtosequence? How many did you connect?
> and a <= B says that a has the value of B
> or am I wrong?
Yes, you are. In no VHDL literature you will find that definition. And
in a port list there only one of the two arrows allowed.
von John M. (215)
Ok.. i correct my mistakes, i've generated the program file, but nothing
appears to happen on the board.
entity top is
end top;
Signal nummer: std_logic_vector (1 downto 0);
port (
      clk : in std_logic;
      bittet: out std_logic_vector (1 downto 0)
end component;
Port (
end component;
begin
randomnumber1 : randomnumber port map(clk => Clock, gameon => Switch, bittet => nummer);
rantosequence1: randtosequence port map(LED1 => LED, randbit => nummer);
end Behavioral;
I've tested each module individually, and the work.
So something must be wrong on how I've connected it.
Gameon is just (on/off switch for the game)
bittet is generate psuedo random number (std_logic_vector(1 downto 0))
using a LFSR.
LED1 is just the LED on the board.
randbit interprets the bittet, and convert to sequence which the LED
displays...
What does the simulation of the complete design say?
> on the board.
Which one?
How did you assign the FPGA pins to your top level entity ports?
von John M. (215)
No errors or warnings.
This is the board
http://www.digilentinc.com/Products/Detail.cfm?NavTop=2&NavSub=451&Prod=NEXYS2&CFID=4697254&CFTOKEN=4c18b30037a8e895-F722082E-5056-0201-02AE9233606926E0
Yes, my port declarations is of the ports in top module.
NET "LED"          LOC = "J14";
NET "gameon"              LOC = "G18";
NET "CLK"        LOC = "B8";
There are some mismatches!
These are four pins:
This is one pin:
And there is no gameon in the port of your top level entity:
Pls post your VHDL file(s) and your UCF file for having a look at it...
von John M. (215)
Ahh.. sorry
I gave you the wrong one..
  NET "switch" LOC = "G18";
  NET "LED<3>"  LOC = "R4";
  NET "LED<2>"  LOC = "F4";
  NET "LED<1>"  LOC = "P15";
  NET "LED<0>"  LOC = "E17";
  NET "CLock"   LOC = "B8";
Here is my LSFR - Randomnumber1
http://pastebin.com/SeBBtRr4
Here is my RANDOMsequence1
http://pastebin.com/CB5HQhe6
(don't worry is only few lines of code)
